Threads: 4
Any body knows how to adjust low beam (up/down) on RS? There is only one screw on the left side of the lamp which can be adjusted left/right for the beam, can not make it up/down. My low beam is very high, there should be another screw for up/down. Thanks.
Likes Given: 789
2 big allen bolts that hold the headlight bucket on if it's like other CBs
http://cb1100forum.com/forum/showthread.php?tid=905
sorry pics are missing
Threads: 27
Loosen the two bolts shown as #23.
rotate the entire headlight down to desired position.
Then tighten two bolts #23
note: for left to right adjustment, tighten the #5 bolt w/ philips head in cw for aiming towards right (when seated on bike) , ccw for left aim.
Threads: 4
Thanks @ the ferret and jedd.
