Dynamic balancer
Hi guys, got a question about the dynamic balancer. When does it need adjusting?
Does it balance the crankshaft or the transmission shaft?
Thanks in advance.
This might help!
https://www.youtube.com/watch?v=mEgQmyknW_4
(04-09-2018, 11:29 AM)Jeya_imp Wrote: Hi guys, got a question about the dynamic balancer. When does it need adjusting?
Thanks in advance.
Hi Jeya, do you mean the balance shaft that is located in the front right of the engine or another part?
The balance shaft looks like this and is actually not dynamic, it counter rotates with the crankshaft and the adjustment is for close ( but not too close ) meshing of the teeth with the eccentric shaft to avoid noise and wear on them;
it is described by wikipedia here; https://en.wikipedia.org/wiki/Balance_shaft
Normally this does not need adjustment but can be checked for correct meshing of the teeth if an obvious rattle is heard in the area near the eccentric adjustment shaft like in this video;
balancer check starts at 2 min.
So unless there is a rattling noise heard there is no need to do anything, i have not heard of any cb1100 that needed adjustment in this area.
And thanks Tuantran!
Awesome. Thanks guys
  Should I adjust my crank balancer? DutchRutter 16 1,194 05-29-2022, 07:39 AM
Last Post: DutchRutter
  Tire Changing & Balancer equipment ? bflint 17 1,234 12-06-2020, 04:45 AM
Last Post: spechg
  Crankshaft Balancer backlash adjustment screw tomas_imp 12 879 05-17-2016, 07:28 AM
Last Post: furious_blue_imp
  crankshaft balancer backlash adjustment dlhmatt_imp 75 5,300 04-20-2016, 10:07 AM
