Threads: 3
Good day all! Just looking for some feedback on if anyone has heard of someone trying to do an ABS conversion for an EX 1100. It is the ONLY thing I do not absolutely love about this bike and would have bought an ABS model if there were any around me. I searched all over, but found nobody talking about this. If there are any posts already about this I apologize in advance. Wondering if it would be a bolt on swap if the right parts could be found. Any help is greatly appreciated. Thank you for your time riders.
Likes Given: 142
It will cost a fortune and a ton of work.
Threads: 33
Likes Given: 6
(11-26-2018, 08:01 AM)Lord Popgun_imp Wrote: It will cost a fortune and a ton of work.
Very succinct answer, popgun!
Micahgerv, just for a start,compare the wiring diagrams between ABS and non-ABS. The ABS modulator is a 12 wire device, requiring an additional speed sensor on the front wheel...and that is just the basic electrical aspect.
I had ABS on my 2016 Mto Guzzi V7II and never used it for 7,000 miles.
Flushing the MG system is rather complicated.
ABS might have prevented my first M/C crash in 1963 or I might have been decapitated. Does that help you feel better about not having it?!
Likes Given: 996
My personal short answer is no, you will not be successful with ABS installation...just to start with the co$t, not to mention about complex-technical....and I do not remember if any member ever mentioned about it?
Threads: 115
Much cheaper to look for a ABS model from any year than to convert one.
Bleeding the ABS system on the CB 1100 is very easy , especially if you use vacuum bleeder and air compressor and speed bleeders .
Likes Given: 142
Just the ABS modulator for a ‘17 is $1400 USD list. Plus the wiring, hoses brackets, tone ring and sensor and all. Plus, maybe a different ECU (don’t really know.
Heck, buy a bike with ABS and be done with it. Cheaper, and you know it will work correctly.
Likes Given: 1,010
I have this recollection that someone on this forum explored this option once before, but I can't seem to find it.
Threads: 33
Likes Given: 6
(11-26-2018, 09:06 AM)Houtman_imp Wrote: Much cheaper to look for a ABS model from any year than to convert one.
I think you mentioned that before. Good to know. Although a valve adjust is super simple and accessible on the V7II, changing the clutch is more than expected on a M/C. Just the nature of the beast.
(11-26-2018, 09:14 AM)Lord Popgun_imp Wrote: Just the ABS modulator for a ‘17 is $1400 USD list. Plus the wiring, hoses brackets, tone ring and sensor and all. Plus, maybe a different ECU (don’t really know.
Doubt it matters, since that $1,400 plus everything else should scare off 99.9% of us, but the ECM appears to not be involved and both ABS and non-ABS have the same connections (A-1 to A-33 and B-1 to B-33). Modulator is powered from fuse H (not present on non-ABS).
Since I probably came across negative, I thought I would add a positive note!
Popgun, does the service manual have a hydraulic schematic? Don't need it, just curious if available.
Likes Given: 996
My shop manual shows simple hydraulics for bleeding only:
* lever brake line p. 14-10
* pedal brake line p. 14-13
Not really hydraulic schematic, as we may think of.
Likes Given: 142
Sportsterdoc, The ‘14 manual does have 2 hydraulic schematics for the ‘13 C-ABS. One shows operation when using the handlebar lever and the other when using the foot pedal. Pages 14-10 and 14-13
Nothing on the ‘13 non-abs or ‘14 abs or non-abs. (Diagrams that is)
I don’t have a ‘17 manual. If Honda doesn’t bring a ‘19 model over I’ll get one. If they do I’ll wait some more.
