2014 Won't Shift Out Of Neutral...
Hello all,
I have a 2014 I bought new in August. I haven't ridden it for a few weeks but it doesn't shift out of neutral without shutting down no matter if I shift up or down. Has anyone experienced this and what was the fix? The bike doesn't have the first 600 miles yet and I wasn't sure about adjusting the clutch but maybe the next step. Thank you.
sound like you need to get it to a dealer. I don't recall anyone on this forum having this issue.
Sounds like a sidestand switch. Any chance it got got unplugged or wires chewed by mice?
(12-29-2018, 02:55 PM)pekingduck_imp Wrote: Sounds like a sidestand switch. Any chance it got got unplugged or wires chewed by mice?
I will look at that. Thanks.
Sidestand switch is essentially a kill switch when in gear.
Dumb question HMM: How is the engine idle? Too high?
Nevertheless, as Ferret suggested, sounds like it is covered under "new" warranty.
Have you tried when rolling? I've had trouble switching gears a couple times at a stop, but usually rolling the bike forward a bit while trying fixes it.
IMH, I think the problem is that, when HMM puts the bike in gear, the engine stops running.
Hmm cCormanus you made me think of something.... clutch interlock switch left handlebar, not plugged in well.
I thought his transmission was malfunctioning , but I'll bet it's that switch.
(12-31-2018, 05:43 AM)Cormanus_imp Wrote: IMH, I think the problem is that, when HMM puts the bike in gear, the engine stops running.
Does that imply a defective side stand switch, or as already mentioned by the Forum, side stand switch cabling? Didn't think of Ferret's idea of clutch interlock switch (or its cabling).
Good thinking Ferret. I had some trouble with mine at one point. I think the connection had worked loose.
  Long shift lever Sam Mac_imp 1 270 02-08-2023, 08:30 AM
  Neutral safety problem- boatdetective_imp 15 895 06-05-2021, 10:18 PM
   neutral problem rocketz_imp 29 2,072 09-16-2020, 03:46 PM
Last Post: rocketz_imp
  Gear shift indicator stuck on 4 bflint 39 2,715 03-11-2020, 02:46 AM
  Bike acting like it’s in neutral when it’s in 1st gear carlenn_imp 29 1,749 08-08-2019, 09:18 PM
  Adjusting shift and rear brake levers DBM_imp 4 359 08-04-2018, 10:13 AM
Last Post: DBM_imp
  Hard to down shift quail_imp 30 3,447 05-14-2018, 05:40 PM
Last Post: jtopiso_imp
  Clunk shift or no shift quail_imp 5 431 11-25-2017, 03:42 AM
Last Post: swifty_imp
  Quick shift sethrose_imp 17 1,067 01-17-2015, 12:04 AM
Last Post: CIP57_imp
