How screwed am I?
Took the bike out for a quick spin this past weekend due to some oddly-warm temps for a Midwest winter. I pulled over quickly to make a helmet adjustment and the kickstand did not bite enough causing the bike to fall to the left. In doing so, it scratched up a cover of the speedo/tach cluster. Not horrible so far but I also noticed that the whole cluster felt somewhat loose. Upon removing the headlight assembly and seeing the damage I found that the actual interior housing for the speedo/tach (white plastic that holds the electrical boards) has cracked and I am looking at around $600 for a replacement. The crack isn't any longer than 1-1/2 inches and I am wondering of trying either a JB weld job or bring it into work and have a guy try and plastic weld it up.
What do you all think? Would you just pitch it and pay the cash or try and repair it? I do not intend to ever sell this bike, especially to an unsuspecting person if I did not replace the part and patch it up.
Thanks,
thebrawnyman
I would absolutely repair it. If you know someone who can weld plastic, ask him if that would be stronger than JB Weld. Me? I would use JB Weld because I know how strong it is. Even the quick set should do fine on that repair, and it sets up a lot faster than the regular stuff. They also make a putty that sets up very quickly.
If the bike's a new 2017 EX or a low miles 2014 DLX, i would "consider" a new replacement.
But if it's a 2014 standard, I'd just JB weld that crack.
That's just me...others may not feel as nonchalant as i do with this issue...
Dang, that's tough luck! The 1100 is a heavy bike and doesn't sit well on a soft surface which is why I carry a plastic "puck" for the sidestand if the surface is iffy.
This is a tough one and really comes down to your own decision and how much you want to spend.
However, since you plan to keep the bike, why not try to repair it as best you can. You have nothing to lose.
If it works, fine. If not, then I guess you'll have to bite the bullet and go for new or used if you can find it.
I had the same thing happen to me years ago with another new Honda I had, but luckily I was standing right next to the bike and was able to grab it as it slowly sank to the left. Phew, that was a close one Big Grin
If it were my bike, I certainly would repair it. Not only for the cost savings, but because the bikes actual mileage would be rolled back to zero, a problem if you have it serviced or when you do sell or trade it.
Strengthwise, either plastic welding or JB weld should be more than adequate. I would opt for the plastic weld because it may be cleaner looking, and because in the unlikely event the plastic weld should ever fail, you can always revert to the JB weld. (You couldn't do it the opposite way).
If it were my wallet, I'd attempt the repair and live with the results.
(01-08-2019, 12:59 AM)jedd_imp Wrote: If the bike's a new 2017 EX or a low miles 2014 DLX, i would "consider" a new replacement.
Its a 2014 DLX with ~ 7500 miles.
(01-08-2019, 01:20 AM)pekingduck_imp Wrote: If it were my bike, I certainly would repair it. Not only for the cost savings, but because the bikes actual mileage would be rolled back to zero, a problem if you have it serviced or when you do sell or trade it.
I was wondering about the speedo being reset to 0. I haven't consulted my service manual yet but I was really hoping the on-board computer and memory was not housed in the dash but elsewhere. If it was, I could swap it out without any resetting problems. I'm assuming from what you said that this will not be the case.
Is the part # 37120-MGC-N41, meter Assy....? $587.15 at Babbitts....try COMEBACK10 code for a 10% discount in case you need to replace it. ($528)
That’s the part # for the standard....the deluxe is 37200-MGC-A71....$573.39 retail...$516 discounted
I think POWERDUBS has an even better discount code...
On all Honda motorcycles (with the possible exception of the new Gold Wing), the odometer reading is burned into a chip in the actual meter assembly and is not changeable. The tripmeter zeroes out when the key is shut off or power is disconnected.
i am a friend of original whole parts....
  I screwed up big time.... PowerDubs_imp 72 4,401 07-04-2022, 03:11 PM
Last Post: max
