05-09-2022, 09:28 AM
...and it was very easy to do.
I was putting my battery back in my bike today- and above the battery is where I have the power commander and autotune as well as a USB from the PCV to the side of the frame and a Battery tender charge cable- so both are accessible from the side of the bike to plug in so I do not need to remove the seat every time I want to read/write autotune files or plug the charger into the bike.
Reason I am telling you that- is I have a lot of cables in the area where the battery goes. The Battery Tender cable is black and the positive end has a red part right at the O-ring connector.
![[Image: 06e0f5a790f0d527db7948a8eb56cd51.jpg]](https://cb1100forum.net/forum/uploads/imp/202205/06e0f5a790f0d527db7948a8eb56cd51.jpg)
I have the autotune hooked positive into my switched tail light- and used the included O-ring connector that came with the autotune kit to connect the negative to the battery.
Notice the included O-ring has a red end.
Unfortunately today when putting my battery back in the bike- I grabbed the black cable with red end that is the Battery Tender wire- AND the black cable with red end to the auto tune box and put them on my + battery terminal- not realizing my mistake, so I put + to the negative of the autotune box.
As I was tightening the screw- I heard sizzling and then see / smell smoke. Arrgh!
I figured I fried the autotune box- so I uninstalled it- then plugged the PCV into my computer and turned off the autotune option. But the bike won't start, won't even fire a put put- just cranks.
SO- I disconnected the PCV harness and tried again- still won't start.
Could this have fried my ECU? The PCV shows no errors on the software- but the case has a smell. I'm not sure if I should try to pry open the Autotune and PCV to check for burn marks.
![[Image: a88b740bbe523a640000bc5e5007eeea.jpg]](https://cb1100forum.net/forum/uploads/imp/202205/a88b740bbe523a640000bc5e5007eeea.jpg)
![[Image: 381984e898038f333c3b3218db5a42bd.jpg]](https://cb1100forum.net/forum/uploads/imp/202205/381984e898038f333c3b3218db5a42bd.jpg)
![[Image: 179a4e55b680e2ced94fae3daf569d53.jpg]](https://cb1100forum.net/forum/uploads/imp/202205/179a4e55b680e2ced94fae3daf569d53.jpg)
![[Image: a74180f994e91d7f9ffdb5643448ca27.jpg]](https://cb1100forum.net/forum/uploads/imp/202205/a74180f994e91d7f9ffdb5643448ca27.jpg)
![[Image: fa9988f3f08c1db49b9e13dac71d372a.jpg]](https://cb1100forum.net/forum/uploads/imp/202205/fa9988f3f08c1db49b9e13dac71d372a.jpg)
![[Image: cd78b709ce23de331d515a62a4bfa226.jpg]](https://cb1100forum.net/forum/uploads/imp/202205/cd78b709ce23de331d515a62a4bfa226.jpg)
