CB1100 compared to recent Nighthawk 750
I've been looking at the CB1100 and also the nineties Nighthawk 750. The Nighthawk is appealing because they are cheap and reliable. I rode a friends Nighthawk last night. The 750 had as much power as I would ever need so the 1100 would likely be overkill. What I did not care for about the Nighthawk was the seating position. It felt like I had to really lift my feet to get them on the pegs. Also the riding position felt leaned forward like a sportbike, not like a standard. How does the CB1100 compare in respect to the seating position? I'm looking for the bolt upright riding position that the 80s UJMs usually had. I'm 6 foot tall and don't want to feel cramped. My usual bike is a Kawasaki Vulcan 1500. It fits me well but I'm looking for something lighter and quicker.
Take a look at the ergo's of the Nighthawk: http://cycle-ergo.com/Riding/04wi0429IaR...UyUy0n.png
Now take a look at the ergos for the CB: http://cycle-ergo.com/Riding/04wi0634IaR...UyUy0n.png
You can also go to this [url=http://cycle-ergo.com/]site to plug in other bikes. It appears with the CB your knees are a bit more bent.
Ultimately, you need to sit on one in the showroom and possibly test ride for as long as you can.
(10-02-2013, 11:12 PM)keithert_imp Wrote: I've been looking at the CB1100 and also the nineties Nighthawk 750. The Nighthawk is appealing because they are cheap and reliable. I rode a friends Nighthawk last night. The 750 had as much power as I would ever need so the 1100 would likely be overkill. What I did not care for about the Nighthawk was the seating position. It felt like I had to really lift my feet to get them on the pegs. Also the riding position felt leaned forward like a sportbike, not like a standard. How does the CB1100 compare in respect to the seating position? I'm looking for the bolt upright riding position that the 80s UJMs usually had. I'm 6 foot tall and don't want to feel cramped. My usual bike is a Kawasaki Vulcan 1500. It fits me well but I'm looking for something lighter and quicker.
Very cool site. Thanks for posting it.
Later Nighthawks had hydraulic adjusted valves; I'd very seriously consider one. I don't think the power is all that different but the ergo's may favor 750 in your case. Between seats and lowered pegs there are options for you. On the down side (and only if you don't ride much), the 750 uses carbs and the 1100 uses EFI. I much prefer EFI today.
Are you saying the CB1100 has a more sporting riding position that the Nighthawk?
One of the bikes I sold to get my CB 1100 was my 2000 Nighthawk 750. I owned the Nighthawk 7 years (along with 4 or 5 other bikes and put about 25,000 miles on it. It was a nice bike. The good..hydraulic valves, and I believe the drum rear brake actually worked better than my 1100 disc rear brake. There is no epa crap and the bike is easily serviced by the owner. The bad the 750 has a poor front brake compared to the 1100 and it has a little less power. With the 750 it felt like I was always riding it harder than I liked. It didnt help that one of the other bikes in my stable was a 2001 FZ 1 with much more horsepower and much better braking...and much better handling. I put a fork brace and rear shocks on the Nighthawk which helped.
The Nighthawk 750 did not exactly have 70s UJM ergos, but it was close. Very much like the CB 1100. The footpeg position was a little more forward on the 750. The 1100s are higher and further back. With both bikes tire choices are very limited, as are accessories at this point.
Its true that you can find a used 750 NH for about $8K less than a new 1100, and if you are just using it for transportation it 's hard to fault. You are buying a bike with 10 to 20 year old ( depending on year of NH) electronics, shocks, for seals etc, and you have no idea if/ how it was maintained/ treated over the decades. Buy used and you are rolling the dice. Not bad if you are mechanically inclined, horrible if you are not and something goes wrong. Sometimes its nice having a NEW motorcycle with a warranty.
I'm currently riding one of each. I rode the CB750 yesterday and I'm riding the CB1100 today. Not sure which one I'll ride tomorrow.
With regard to the ergos, they are very similar. The CB1100's footpegs are just a bit farther back than the CB750. Maybe an inch. As far as I can tell, peg height on both is about the same. I really don't see a great deal of difference in the ergos between the two. I owned quite a number of UJMs in the past and as far as riding position goes, both the CB750 and CB11 are pretty similar. YMMV, but I've never heard anyone else compare the Nighthawks riding position to that of a sportbike. I bought mine specifically because of the upright, standard riding position I was used to from my UJM days.
I consider the CB1100 to be sort of a Super Nighthawk. It's got all the things I love about the Nighthawk, with more power, greatly improved brakes and better suspension (and, of course, a much higher price tag).
I've only had the CB11 for 5 months, so I can't say much about the reliability, other than I've had zero issues with it. On the other hand, I bought the Nighthawk brand new 17 yrs. ago and it has been bulletproof. Other than replacing consumables (oil, tires, chains, etc...) it hasn't required any other maintenance,,,except for a stripped spark plug hole that I caused Sad
Overall, I think both bikes are pretty similar when compared with everything else on the market. If you're looking for cheap and reliable, the Nighthawk may be your best bet. If you want upgraded performance, modern engine controls (EFI/ECU) and nearly flawless fit/finish (and you're willing to part with $$$s), the CB1100 may do the trick.
If the ergos are an issue, consider a higher seat, lower pegs, different bars. You can tailor either one of these to fit your needs.
If that Nighthawk felt like a sportbike to you I'd be asking the quiest "has this bike been modified?". I.E. lower handlebars or different pegs or whatever because in its stock form it is FAR from a sportbike riding possition.
I traded my 93 Nighthawk in on my CB1100 and I miss the hydraulic valves, but I can live with that. This CB is a better bike all around if you asked me. The one thing that bugs me (but only a little) it the fact that they actully engineered vibration into the bike with the cam timing. I think it would have been better off perfectly smooth, but it's only a VERY MINOR amount, so don't let that scare you off from it.
(10-03-2013, 05:55 AM)Randy B_imp Wrote: If that Nighthawk felt like a sportbike to you I'd be asking the quiest "has this bike been modified?". I.E. lower handlebars or different pegs or whatever because in its stock form it is FAR from a sportbike riding possition.
When I last test rode a NH back in 2002 I remember having a back ache the next day from leaning forward. The cruisers I'd been riding didn't have that position. Now one of my bikes is an XT225 dual-sport bike so I'm used to both upright and laid back riding positions. Many years ago I had a Kawasaki Concours. I absolutely hated the weight on wrists riding position it had.
I've thought about the timing thing too when I read about it. The Nighthawk has such a nice smooth engine I hope they didn't mess that up.
Hi guys;
I am thinking of adding another Honda to my stable, and the CB1100 is on my short list! I want a larger displacement motorcycle for longer highway rides.
I like everything about the CB1100 except for the lack of hydraulic valves. I currently ride a mint 2001 Nighthawk, and I am wondering if I should keep it or sell it (what did you do?). Is the CB1100 a true improvement/replacement over the CB750, or do they compliment each other? My Nighthawk is bone stock, with the exception of a beautiful 4-1 Supertrapp exhaust system, Progressive springs up front, some key OEM add-ons, and a Corbin seat. Braking is decent now, especially after a full rebuild of the front master cylinder, but they lack compared to modern setups. It produces about 80 hp at the crank with the Supertrapp installed. Overall, I am happy with the performance, but I would like a bit more low-down torque, hence the reason for my interest in the CB1100. I could use the money to put towards the CB1100, but I worry about "giving it away".
[Image: 1c02f1d3c696ca5e66f73fe46370627a.jpg]
[Image: d7aa7c18c09062874d291f8f03a0f8dc.jpg]
Oh one other point... my Nighthawk is only 5-speed, and I find that the engine is revving fairly high at highway speeds... and this is another reason why I am craving a larger displacement motorcycle. What rpms are you turning at say 120 km/hr? Sorry I don't have the mph conversion. Thanks!
  Recent purchase, whats next? Classico_imp 8 629 03-28-2022, 03:36 AM
Last Post: apex1_imp
  Nighthawk vs. the new CB Mike_imp 31 2,119 11-13-2018, 12:18 PM
Last Post: DHB_imp
  Is that a nighthawk? Brookland27_imp 4 326 09-13-2016, 08:31 PM
Last Post: Guth_imp
  Update on my recent purchase, and some ride pics! kvdv_imp 11 877 08-19-2015, 04:40 AM
Last Post: drodg33
  13 trade sell value recent info. Romo1969_imp 7 551 02-19-2014, 03:28 AM
Last Post: Red Mist_imp
  Compared to the classics ..... the Ferret 25 2,858 07-17-2013, 07:05 PM
Last Post: Buffalorider_imp
  Nighthawk vs, cb11 vibration rekit_imp 4 386 06-17-2013, 12:41 AM
Last Post: Randy_S_imp
