Torque specs for Engine Gaurds
I noticed that on the 2014 CB1100 that the engine gaurds that you can buy use some of the Motor mount bolts or locations.
Do these need to be re-torque'd if you add engine gaurds?
What is the proper torque?
I saw this post yesterday and meant to respond. The short answer is, yes, the bolts need to be re-torque'd. Of course, some will say they have built in ft-lb readings in their forearms but I personally like to use a proper wrench. I believe I still have the paperwork for the engine guards that may have listed the specs but, if not, I'm expecting my service manual any day now and will take a look and edit this post as soon as I have the information (unless someone else beats me to it - hint, hint).
(03-17-2015, 11:15 PM)metalmaven_imp Wrote: I noticed that on the 2014 CB1100 that the engine gaurds that you can buy use some of the Motor mount bolts or locations.
Front engine bracket nut 36 lbf-ft
Front Engine Hanger nut ( if used ) 44 lbf-ft
Bracket nuts are the two on the frame ( Black)
Hanger Nut is to the rear of them
Thanks a lot guys!
  Stock handle bar specs mvk24_imp 6 602 07-06-2023, 09:22 AM
  Oil Filter Torque ohiorider_imp 11 715 11-18-2017, 03:58 AM
Last Post: SportsterDoc
  Rear axle torque question. jdvalero_imp 10 946 03-21-2017, 09:29 PM
Last Post: jimgl3_imp
  Euro ergo specs? jimigalahad_imp 5 459 04-22-2015, 09:08 PM
Last Post: JF Coastal_imp
  Torque Wrenches Chapomis_imp 7 454 03-26-2015, 06:38 AM
Last Post: Chapomis_imp
  Chip Beck Explains HP vs. Torque for Mr. Ferret ChipBeck_imp 36 2,407 03-20-2015, 02:56 AM
Last Post: thessler3_imp
  Horsepower vs. Torque ? Rebel73_imp 47 3,260 03-16-2015, 10:49 AM
