Not an oil thread!
I'm not trying to start another oil conversation but rather find out the answer to a very simple question. Are you running full synthetic without any clutch slipping issues?
Two dealers are giving me different stories. One says no problem, and the other says don't do it. Since they all have very little experience with the CB1100, I figured I would ask to those who ride them, you.
If you're running full synthetic, what do you use? Assuming Honda has some full synthetic oil as well...
I'm also curious to the answer to your question, Ghis. Can I ask if you are experiencing clutch slip?
(07-13-2015, 02:54 PM)lemontree_imp Wrote: I'm also curious to the answer to your question, Ghis. Can I ask if you are experiencing clutch slip?
I'm still running the standard Honda 10W30, but I do want to switch to full synthetic.
Full synthetic for many kilometres. No issues.
I have used full synthetic in my bikes for years now with no problems whatever. Just be sure you use an oil that does not have friction modifiers which are for auto use exclusively. If you use a synthetic motorcycle oil such as Honda recommends for the CB you can't go wrong. A dealer who tells you different hasn't a clue what they're talking about.
Mobil 1 Racing 4T 10w40
No issues here.
Using Motul 300v since the first oil change with no clutch problems. It's overkill, but the shear stability of this stuff (and any ester based oil, including the Mobile 4t mentioned above) can't be beat -- the bike shifts like day one through the whole OCI.
Sent from my BlackBerry Runtime for Android Apps using Tapatalk 2
This is what I run.
[Image: 7a6d0a14551fe34dd3e820e3fd795f4b.jpg]
Hmmm if it quacks like a duck...
Motorcycle oil actually has a rating for this. It's JASO MA or MA2. What this means is no matter what oil you get, clutch performance should fall within the specs outlined in whatever specification the oil meets. Doesn't matter what it's make up is, if it's JASO rated, it's been tested for wet clutches.
Sent from my Z30 using Tapatalk
  The Birthday Thread Part 2 the Ferret 221 15,439 06-02-2026, 07:45 PM
  Winter thread...how long? pdedse 19 1,338 01-18-2026, 09:00 AM
Last Post: Ollie
  Saw this on my news thread SCCBrider_imp 11 862 09-28-2024, 08:05 PM
Last Post: michael1954
  CB Sighting Thread capttwb136_imp 73 4,781 10-10-2019, 02:02 AM
  Not an oil thread .... just an oil change interval question ohiorider_imp 26 1,665 11-16-2018, 02:13 AM
Last Post: Matt F._imp
  Another “is this the bike for me?” thread cblais19_imp 26 1,435 03-16-2018, 02:15 PM
Last Post: kennyw
   The LOW mileage thread: For those who don't ride much DocRid_imp 17 995 08-11-2017, 12:11 AM
Last Post: jedd_imp
  Suspension thread Not an oil thread but it starts that way ohiorider_imp 10 696 05-15-2017, 01:10 AM
Last Post: TCinNC_imp
  Question - can you point me to a particular thread? ohiorider_imp 8 591 04-11-2017, 01:06 PM
  2017 Honda CB1100 EX Anticipation Thread Stichill_imp 43 2,699 12-22-2016, 09:36 AM
