Threads: 81
I took the CB1100 out for a short ride to get the oil up to temp so I can do 'black beauty's' first oil change. As luck would have it, the Honda shop within a couple miles of my house had no GN4 10w30 in stock when I stopped by a week or so ago. So I bought GN4 10w40.
It probably would have caused no harm, but I thought 'every oil reference in the Honda documentation mentions only 10w30,' so after a phone call, I was off in the car on a 50 mile round trip for the recommended weight. The 10w40 will be returned.
Now to the front suspension. I thought, hmmm, before I start buying emulators and new springs, lets take the advice of a couple of forum members and loosen the lower triple clamps, the axle nut, and the axle pinch bolts, and really rock the suspension up and down while holding the front brake. And of course, re-torque everything per Honda specs.
Surprise! The fork action is noticeably softer and smoother than it has ever been. Now, instead of a harsh fork jolt followed by a harsh rear shock jolt, the front end seems to absorb bumps much better, making the shock action that much more noticeable.
So, I'll start off with new rear shocks with springing and valving set up for my weight.
Thanks, guys, for reminding me of this old trick.
Bob
Likes Given: 140
OH BOY! An oil thread!
The service manual says 10w40 can be used in hotter temps. Many members use it. Some have reported a noise that went away when they switched back. You can search for all that.
Check out this post and the one after which is for our bike: http://cb1100forum.com/forum/showthread....#pid102309
Likes Given: 1,002
Can't miss an oil opportunity!
Many of us Down Under use 10w40 with no problems.
Threads: 14
Likes Received: 14 in 9 posts
Likes Given: 20
Gotta pile on when an oil thread comes up!
I tried 10w40 for hotter weather once and the transmission just didn't shift as smoothly and made a lot more noise. Switched back to 10w30 and it was much smoother and quieter.
Threads: 81
So, no one got to the suspension part?
Bob
Threads: 11
cant ever bring up oil on a forum
Likes Received: 603 in 269 posts
Likes Given: 779
I'm happy with my suspension, but yes alignment will make everything work the way Honda designed it. That still might not make some people happy though because the stock suspension is a compromise. No way to make suspenion work for two people, one weighing 135 and the other weighing 250, one an easy rider and one an aggressive rider.
Threads: 3
(05-03-2017, 06:08 AM)ohiorider_imp Wrote: I took the CB1100 out for a short ride to get the oil up to temp so I can do 'black beauty's' first oil change. As luck would have it, the Honda shop within a couple miles of my house had no GN4 10w30 in stock when I stopped by a week or so ago. So I bought GN4 10w40.
Bob
Ok Bob, I will bite since I've been complaining about the harshness of the front suspension. So what is the torque value for the lower triple tree bolts? I'm willing to give this a shot before trying more drastic measures. A friend who is well versed in bike suspensions suggested going to ultra-light fork oil before replacing springs, etc.
Threads: 81
(05-09-2017, 08:37 AM)TCinNC_imp Wrote: (05-03-2017, 06:08 AM)ohiorider_imp Wrote: I took the CB1100 out for a short ride to get the oil up to temp so I can do 'black beauty's' first oil change. As luck would have it, the Honda shop within a couple miles of my house had no GN4 10w30 in stock when I stopped by a week or so ago. So I bought GN4 10w40.
Bob
Ok Bob, I will bite since I've been complaining about the harshness of the front suspension. So what is the torque value for the lower triple tree bolts? I'm willing to give this a shot before trying more drastic measures. A friend who is well versed in bike suspensions suggested going to ultra-light fork oil before replacing springs, etc. Lets see if this copy and paste will work: (It doesn't)
So, here's the info from the CB1100 600 mile service schedule that I picked up from a local Honda dealer. Probably copied from the Shop Manual.
I'll tell you now, I noticed a difference, but the rear shock is still beating the crap out of me. And the front fork isn't right for my weight. Your friend may have the right idea re thinner fork oil (if it is in fact a damping issue.)
Triple Clamp Bolts Upper Torque: 17 FT/LB
Triple Clamp Bolts Lower Torque: 32 FT/LB
Front Axle Torque: 44 FT/LB
Front Axle Pinch Bolts: 19 FT/LB\
Please note ..... I didn't loosen the top fork pinch bolts. They're the ones that kept the forks from sliding up thru the triple trees.
I loosened ( a couple turns)
- lower pinch bolts
- axle bolt
- axle pinch bolts
Threads: 3
(05-09-2017, 11:17 AM)ohiorider_imp Wrote: (05-09-2017, 08:37 AM)TCinNC_imp Wrote: (05-03-2017, 06:08 AM)ohiorider_imp Wrote: I took the CB1100 out for a short ride to get the oil up to temp so I can do 'black beauty's' first oil change. As luck would have it, the Honda shop within a couple miles of my house had no GN4 10w30 in stock when I stopped by a week or so ago. So I bought GN4 10w40.
Bob
- lower pinch bolts
- axle bolt
- axle pinch bolts
- lower pinch bolts
- axle bolt
- axle pinch bolts Thanks Bob, I'll give it a try and see what happens.
