Threads: 36
Does the Samurider Top Box lock? If so, different key?
Does it hold a full face helmet?
How quick and easy is it to take off the bike?
Are used ones ever available?
Does it effect the handling?
Thanks!
Likes Received: 875 in 478 posts
Likes Given: 1,006
If the Samurider top box is the Honda OEM top box, it can use a Honda one-key system so it can work with your ignition key. There are instructions on the forum for setting it up.
Yes, it holds a full-face helmet.
Ask RandyB about getting it on and off (I have a Givi Monolock top box which is really easy to take on and off.)
I've never seen an ad for a used one.
It almost certainly affects the handling, but not enough for me to notice.
There is also no question that it affects the aesthetics negatively.
Threads: 85
Likes Given: 129
Nothing that I have noticed. I guess it would if you have it full of heavy stuff, but the way I have it, it really has no major impact on handling.
It is the one key system that you have to key to your bike. It's not that hard and I did it using the Japanese instructions and just following the pictures, but there are translated instructions somewhere on the forum.
Yes it holds a full face helmet quite easily.
Likes Given: 141
The translated instructions are in the How-To section :
http://cb1100forum.com/forum/showthread....6#pid41636
