Easy question re trip meter reset
Just took delivery of 2014 Black Standard yesterday, and rode 245 miles from the dealer in Clarksburg WV to Hudson OH. Sweet machine!
Question - I've read and reread the page in the manual that describes how to reset the TRIP 1 and 2 meters, but no success.
I'm .....
- turning on the ignition/leaving engine off
- depress the 'A' button to cycle from Total to TRIP1
- release 'A' and depress 'B' Button to zero TRIP1
- nothing happens/still displays TRIP1 mileage/won't zero out
- same if I display TRIP2
What's the secret?
Thanks
Bob
(04-10-2017, 10:20 PM)ohiorider_imp Wrote: Just took delivery of 2014 Black Standard yesterday, and rode 245 miles from the dealer in Clarksburg WV to Hudson OH. Sweet machine!
I'm .....
What's the secret?
Thanks
Bob
Press and HOLD "A" button to reset...
Press and HOLD button at least 2 seconds to reset...
You can reset trip A without affecting B and I do every day. Trip A I use for daily mileage, trip B for fuel mileage on the tank. I might zero A 3 or 4 times before I need gas in the tank. When I fill the tank, I zero B and it doesn't affect A at all, just the functions of B... (Miles since B was last zeroed, ave mileage since B was last zeroed, and fuel used since B last zeroed).
Zeroing A will ..... Zero mileage since A was last zero'd, zero gas mileage since A was last zero'd, and zero amount of fuel used since A was last zero'd. It doesn't affect B at all.
Zeroing B will ..... Zero mileage since B was last zero'd, zero gas mileage since B was last zero'd, and zero amount of fuel used since B was last zero'd. It doesn't affect A at all.
The button cycles thru in order.... odometer, trip A (3 functions) trip B (3 functions) and real time mileage then back to odometer. At point A you can zero the 3 A functions by pressing and holding the button without affecting B. You can also cycle thru to B and zero it by pressing and holding (3 functions) without affecting A. You can zero A and B without affecting odometer. Real time gas mileage only shows up while you are running I do believe
Thanks, guys. I had been using a copy of the manual for the 5 speed (2013 CB1100) instead of the small hard copy that came with the bike. My older manual indicated shifting to Trip1 and Trip2 using the "A" button, then cancelling trip mileage(s) using the "B" button.
Bob
Be careful with that Ohiorider. The torque spec for the rear axle is also different for the '13s and '14s as the axle is different.
(04-11-2017, 02:47 AM)Lord Popgun_imp Wrote: Be careful with that Ohiorider. The torque spec for the rear axle is also different for the '13s and '14s as the axle is different.
Thumbs Up
Bob
The 2014 has a whole range of meter functions not available on earlier models.
(04-11-2017, 08:51 AM)Cormanus_imp Wrote: The 2014 has a whole range of meter functions not available on earlier models.
I'll read up on all the dash features. I'm excited about the CB1100 ...... I love twins, but believe the DOHC 4 cylinder Honda will be a unique addition to the very small stable of bikes I own (not sure two other bikes qualifies as a 'stable.'
Ohiorider
Ohiorider
Of course it does. I reckon one bike qualifies. But then I would say that.
A stable would only refer to the garage you store things in, nothing to do with number of bikes you have.
Like horses, a stable is the building they stay in. Doesn't matter if it is one or 100.
  making moderating easy the Ferret 9 640 08-21-2024, 10:28 AM
  state-by-state m/c law, with easy to use maps The Gecko_imp 3 396 08-01-2023, 02:29 AM
Last Post: The Gecko_imp
  Trip Meter operation LakeWylieJoe_imp 24 1,622 08-16-2020, 07:01 AM
Last Post: LakeWylieJoe_imp
  How to clean meter cover case? saru2011_imp 3 341 09-06-2018, 01:16 AM
Last Post: rboe
  Trip Question josiah.hurt_imp 9 592 07-18-2017, 06:58 AM
  Easy question... quietguy_imp 3 343 12-14-2015, 07:02 PM
  New Key - Not so Easy Offroad 11 714 07-28-2015, 10:54 AM
Last Post: Pauley
  Taking it easy Voitus_imp 13 800 03-08-2015, 08:09 PM
Last Post: Headbanger02_imp
  So So I went to the Easy Riders Bike show today... OldF7Guy_imp 3 346 02-08-2015, 02:15 AM
  CB11 at the location of Easy Rider's Final Scene. buck80mph_imp 8 721 10-01-2013, 02:45 AM
Last Post: The Spaceman_imp
