Removed tank sticker -- now need advice
I bought my Valk when it was one year old and the original owner had left the safety sticker on. I had it off about 5 minutes after I got home using methods I no longer remember. Then, I wiped the tank down with WD-40 and everything looked good.
But, I've come to realize that when the tank surface dries that I have tiny white scratches in the clear coat starting at where the outside of the sticker was and extending out about 3/16 inch.
It's no biggie, but I'd like to get rid of those really fine scratches. I have on hand some Flitz metal polish (and of course, toothpaste). I was wondering if any body has tried to polish clear coat with some mild abrasive like either one of those and did it successfully. Or am I flirting with danger even thinking about such a thing?
Go get a swirl remover for auto paint. You really don't want to cut through the clear coat. Work up from there with a stronger scratch remover if needed. Some are a combo and do both swirls and minor shallow scratches.
Always start with the least aggressive and work to the more aggressive.
Thank you popgun; it shall be done!
Good for you!!
I forgot to say, finish it up with polishing/waxing with your favorite stuff.
Then enjoy your ride.
(08-06-2017, 12:48 AM)postoak_imp Wrote: I bought my Valk when it was one year old and the original owner had left the safety sticker on. I had it off about 5 minutes after I got home using methods I no longer remember. Then, I wiped the tank down with WD-40 and everything looked good.
I have had great success removing fine scratches and swirl marks in the clearcoat on other bikes using a product called Malm's Ultra Fine Polishing Cleaner. With a little patience you can get most scratches/swirl marks out. Then use their pure carnuba wax (contains no compound) to seal and protect the work you did! http://malms.com/malms-ultra-fine-polishing-cleaner.php It isn't cheap, but rarely does anything that works well is. Also, a little goes a long way.
Well, that worked well. I got something called VSS from the ChemicalGuys just because that's what popped up on Amazon. Anyway, 15 seconds with that and that area looks like new.
  Advice on sprocket replacement? Inhouse Bob 5 593 06-24-2025, 12:57 PM
   Need advice on current availability of tires. Frulk_imp 34 2,891 11-04-2024, 11:42 PM
  Advice for a possible Buyer: 2013 vs. 2014 Bighonda14_imp 30 2,301 05-08-2023, 12:26 PM
Last Post: DaSwami_imp
  Need advice on clip ons domenaxe_imp 42 3,260 12-11-2022, 02:33 AM
  Looking for Advice about etiquette on Skyline Drive. misterprofessionality 12 1,188 08-25-2021, 06:44 AM
  Sticker shadow Rantsc_imp 15 1,082 05-09-2021, 04:42 AM
  Whitehouse tank dimensions vs CB750 tank dimensions spartanheed_imp 2 352 04-27-2019, 05:40 PM
Last Post: spartanheed_imp
  Seeking Trip Advice, Gulf coast to Texas. misterprofessionality 17 1,340 01-01-2019, 03:33 AM
Last Post: Lou07_imp
  2013 price advice please superjim_imp 7 583 01-01-2019, 01:41 AM
Last Post: af_one_imp
  Route Advice Sought - Franklin, TN to Tellico Plains, TN emptysea 12 889 09-29-2018, 06:37 AM
Last Post: 4 Paws_imp
