Advice on sprocket replacement?
I'm doing lots of maintenance on the bike and want to replace the chain and sprockets. The chain and back sprocket are sort of clear, but the front is a mystery. My service manual is no help. It shows how to reassemble everything but has nothing on how to take it all apart. I tried turning the book upside down but that didn't help much.  Tongue
So, do I have to disassemble the clutch hydraulics to remove the plate covering the front sprocket? I feel like if I remove those assorted bolts holding the plate in place, all my clutch juice will spill out on the ground.
Has anyone done this surgery and can give me a rough tutorial?
Thanks in advance!
Been around longer than that! Cool
I've done it, Bob, but I can't remember exactly how. I know, though, that I didn't lose the clutch juice in the process. The slave cylinder comes off intact leaving the pipework connected and you can then get at the front sprocket OK.
By the way, if I can do it, you'll have no trouble. I can't even get the bonding on my service manual to go back together!
^^+1^^
Very simple operation, tool needed 8, 10, 14 or 17, 22, 27 mm wrench or/and socket, ratchet, torque wrench..don't remember exact bolts/nuts sizes..
If you don't have an impact gun, you will have to lock up the front sprocket prior removing its bolt and then torqued it to the spec, 40 ft-lbs??
If you have the shop manual, read it prior wrenching.. p 9-3/9-4, 6-12/6-14
1. remove gear shifter arm from the gear shifter spindle
2. remove all the bolts and the L side cover, allen key M5 or M6?
3. remove gear shifter position switch
4. remove 3 long M6 bolts and swing aside the clutch slave cylinder with the hose attached, do not pump clutch lever or/and separate any hydraulics - keep it as a one unit , won't leak
5. remove clutch push rod and clean it
6. remove the bolts and the cover to gain access to the front sprocket/bolt
7. may have to remove the chain guide plate??
8. give the chain enough slack prior removing the front sprocket
9. remove the the bolt and the front sprocket
10. clean the greasy mess. I use brake cleaner
11. re-assemble in the reverse order
12. pump the clutch lever a couple of times and shift through gears prior riding.
Yes, you can do it!
P.S. keep your service book on the flat table and don't turn it upside down to be successful...otherwise lots of info will be missing  Tongue
           "Drop a gear and disappear"®
'24 Kawi Z650RS - Hooligan®
            *Grand Chancellor*
Just as Peter says.
I assume you are replacing the rear sprocket.  Front sprockets usually outlast rear ones by about a 3:1 ratio, so you likely won't need to touch it until 30K miles.  If you get in there and remove it, but see no wear, flip it over for even more sprocket life.  If you don't use an air or electric impact gun/wrench, the best way to hold the sprocket still is to put it in a higher gear (not 1st or 2nd), and put pressure on the brake pedal, while the old chain is in place.
Also, it's easiest to loosen/tighten/torque the rear sprocket bolts in the same way, with the wheel in place, rather than struggling with the wheel laying on the ground.
Thanks all! Great advice and guidance. I'm at 37k miles so I guess it's about time, though I honestly think everything looks pretty fresh. Next thing, y'all will be telling me I shoulda checked the valve clearances by now!  Confused
Bob, practice with the sprockets first ….. before you dig in the upper end/valves…. as the sprockets to valves ratio is 2:16~1:8… Tongue
            *Grand Chancellor*
   Need advice on current availability of tires. Frulk_imp 34 2,793 11-04-2024, 11:42 PM
   Urgent Tire Replacement Help CB for CST_imp 13 1,550 04-23-2024, 10:19 PM
Last Post: Ollie
  Advice for a possible Buyer: 2013 vs. 2014 Bighonda14_imp 30 2,237 05-08-2023, 12:26 PM
Last Post: DaSwami_imp
  Need advice on clip ons domenaxe_imp 42 3,159 12-11-2022, 02:33 AM
  CB1000 replacement. hondadownunder_imp 13 961 03-06-2022, 04:10 AM
Last Post: Rexburgtom_imp
  Looking for Advice about etiquette on Skyline Drive. misterprofessionality 12 1,162 08-25-2021, 06:44 AM
  Hip Replacement Forces Early Winter Mode Dave Swanson 17 1,439 10-12-2020, 11:56 PM
Last Post: michael1954
  Seeking Trip Advice, Gulf coast to Texas. misterprofessionality 17 1,252 01-01-2019, 03:33 AM
Last Post: Lou07_imp
  2013 price advice please superjim_imp 7 582 01-01-2019, 01:41 AM
Last Post: af_one_imp
  Route Advice Sought - Franklin, TN to Tellico Plains, TN emptysea 12 861 09-29-2018, 06:37 AM
Last Post: 4 Paws_imp
