Question about Givi bag mounts for CB1100
I have a perfectly good set of Givi E21 hard bags. These would be a nice size bag for the CB1100. The problem is, I've been unable to find a set of bag mounts for the CB1100 that would work with these bags. Granted, it appears these bags are no longer in the current Givi product line, but seeing as how they were sold for years, there must be a bunch of used E21s out there.
In the meantime, I've purchased (but haven't installed) a set of Hepco Becker mounts and 30 liter Jr bags, but I'd like to use the E21s instead. These look (to me) visually too large for a trim bike like the CB.
Any suggestions short of making a custom set of mounts?
Bob
I don't know if this http://www.twistedthrottle.com/sw-motech...-sidecases will work with the Givi E21 cases but they do work with other Givi cases. You will need to add the SW-MOTECH attachments for Givi cases to the loops, the loops are drilled for several types of attachments. My guess is that they will work but perhaps some part of the loops may show past the forward/rearward parts of the E21 cases since those cases have their lower mount points quite close to the edges of the case.
Here is how I installed them along with a Honda factory rack on a 2013 CB100 - http://www.cb1100forum.com/forum/showthr...p?tid=6242
(10-23-2017, 10:10 AM)Redbird_imp Wrote: I don't know if this http://www.twistedthrottle.com/sw-motech...-sidecases will work with the Givi E21 cases but they do work with other Givi cases. You will need to add the SW-MOTECH attachments for Givi cases to the loops, the loops are drilled for several types of attachments. My guess is that they will work but perhaps some part of the loops may show past the forward/rearward parts of the E21 cases since those cases have their lower mount points quite close to the edges of the case.
Thanks, Redbird ...... I think these would probably work, and I think you're correct about the lower portion of the mounts sticking out past the E21 cases, due to the profile of the cases. The SW Motech adaptors appear to be the only game in town for the E21s. I may just go ahead with the Hepco Beckers, or sell them and find a lighter set of cases and mounts.
Bob
  Givi E21 Hard Cases KiowaEagle_imp 6 519 10-26-2022, 09:46 AM
  A question about the CB1100 FLYTYM_imp 60 3,986 03-10-2021, 04:35 AM
Last Post: Gus_imp
  Givi Tank Lock Adventure boy_imp 8 617 07-08-2020, 07:09 AM
Last Post: tsmetjen_imp
  Question about HB C Bow mounts and bags ohiorider_imp 4 482 11-12-2019, 07:51 AM
Last Post: ohiorider_imp
  Question re CB1100 rear brake caliper ohiorider_imp 14 986 07-12-2019, 07:12 AM
  Basic question, about to purchase 2013 CB1100 non-abs AsHperson_imp 16 1,478 05-29-2019, 04:37 PM
Last Post: AsHperson_imp
  Comments/Opinions on HB C Bow mounts/bags ohiorider_imp 0 200 01-17-2019, 02:19 AM
  U.S.-spec 2017 CB1100 EX side cover question VLJ_imp 25 1,539 11-04-2018, 12:19 AM
Last Post: VLJ_imp
  Question re drive line lash on CB1100 ohiorider_imp 17 988 08-31-2017, 04:28 AM
Last Post: Rocky_imp
  Pannier mounts for Givi E21 Monokey or HB 30L Juniors ohiorider_imp 12 676 02-01-2017, 12:53 AM
