For those of you wanting to defeat the speed limiter...
I've been doing a bit of reading, purely out of interest mind you as I don't really have any intention using one of these on my bike. (This is an example of the kind of thing I tend to fixate on at night when dealing with my sleep disorder. Sad)
You might want to do a bit more research on your own (and probably should), but for those of you so inclined, I believe these products are what you're looking for.
[url=http://japan.webike.net/products/20034107.html]Special Agent: Negotiator = speed pulse modulator
[url=http://japan.webike.net/products/9688807.html]Magical Racing: Speed Pulse Modulator
Awesome Guth; I love the aftermarket industry!
http://www.calsportbike.com/sh/
then there's the Speedo healer. Corrects Speedo error or for sprocket change but can be set so that for track or speed run the speedo would read way low and never reach the limited speed..... Then switched to normal for normal riding.
I'd have no clue how to install it.
and...let the games begin....!
personally not for me though.. Smile
(06-24-2013, 07:39 PM)Guth_imp Wrote: I've been doing a bit of reading, purely out of interest mind you as I don't really have any intention using one of these on my bike. (This is an example of the kind of thing I tend to fixate on at night when dealing with my sleep disorder. Sad)
yes, sleep disorder is indeed an oppurtunity to learn many things... totally with you on it Guth.. I personally am a victim too.. Smile
(06-25-2013, 04:36 AM)Deanohh_imp Wrote: http://www.calsportbike.com/sh/
This seems like a good idea only if knocked a fixed amount off at all speeds, or showed exactly half actual speed. Otherwise what would you tell your friends? "Yeah, I was going really fast." "Really? How fast?" "I don't know, I disabled my speedo!"
you adjust it to a percent so if you set -90% your Speedo would read 10 if you were going 100. Or -50% your Speedo would read 60 if you were going 120. Also recalls fastest speed of a run so you don't have to guess while you're busy trying not to crash. Or if you're Speedo is simply optimistic all the time you can just go -5.7 or whatever it takes to make it show accurate speed. Has 2 settings that you can switch back and forth.
Anybody tried any of these on there bike yet?
Any thoughts as to why Honda put the limiter on to begin with? Or if the bike is stable/safe above that speed without mods?
VStroms are able to go faster than the stock suspension, windscreen, and bodywork can handle. The fixes are easy enough, but more than one owner crashed or ruined ther riding pants finding that out.
Spaceman..domestically Japan is limited to 112 mph. Our guess is they never removed whatever it is that limits top speed before exporting them.
Well my first thought was cool ill try one but to me it looks like you wouldnt be able to run a fuel controller or maybe it plugs in in a different place? The plan is to run an open header and velocity stacks on mine so a fuel controller is a must. Im really in to the vintage drag bikes and would like to make it look similar to them.
  Speed governor drewdavis_imp 4 528 08-27-2024, 05:49 AM
  Looks like the speed limiter is still on the '14. flynrider 38 3,167 06-12-2024, 05:31 AM
  Top Speed, 125MPH? HikerToo_imp 46 3,137 06-06-2021, 03:28 PM
Last Post: Rox_imp
  Will riding with prolonged speed limiter damage the engine?? zirconxi_imp 10 2,740 03-15-2020, 03:39 PM
Last Post: zirconxi_imp
  Triumph Speed Twin Obleo 5 545 01-14-2020, 01:15 PM
  Low-speed shimmy HondaJon_imp 24 1,544 11-10-2018, 11:36 AM
  2017 Honda CB1100EX, still top speed / rev-limited? DaSwami_imp 42 2,662 07-22-2018, 05:36 PM
Last Post: MaFiHa_imp
  5 or 6 speed? Gear indicator? PAULIBIKER_imp 27 1,811 04-20-2018, 02:07 AM
  Yes Virginia, there is a speed limit. flynrider 52 3,487 06-04-2017, 01:27 AM
Last Post: chync_imp
  CB1100 Speed Limiter.....maybe a cheap fix...just museing Wolfgang_imp 9 748 05-23-2017, 01:24 PM
