CB1100 Speed Limiter.....maybe a cheap fix...just museing
The CB1100 speed limiter can not be removed without disablement of the speedometer.
However, as we have all noticed....most motorcycle speedometers read 5 to 8 mph too high. (i.e. it indicates you are traveling at 60mph when your true speed is 52-55 mph)
I saw this in both my BWW and Kawasaki speedometers.
Now....back to the speed limiter.
In my case I simply want it to allow the bike to do at least 120 mph after I have had the ECU reflashed to remove the rev limiters, and a Yosh exhaust installed. That should make the bike quick enough and fast enough to avoid being embarressed by some Harley.
Now to the theoredical fix. The CB1100 has a sensor ring on the rear wheel that is used to determine the bike's speed. You can not remove the ring, or disconnect the speed limiter wire, without loss of the speedometer readout.
The CB1100 comes with a 140-70 18 in. rear tire. If you replace that tire, when it wears out, with a 140-80 18 in. tires the "taller" replacement tire will yield an increase is speed, over the 140-80 tire...of about 8-12% (conservatively) ....at the same rpm. (depending on the tire you select). What you are doing is changing the aspect ratio of the stock tire to a tire that is taller and has an increased diameter. Kind of like the old steam locomotives. They had limited revs to work with so they used smaller diameter driving wheels on freight locomotives that did not need to go fast, but pulled heavy loads.....and larger wheels on the passenger locomotives that pulled lighter loads and needed to enjoy increased speeds.
112% of 112 mph is about 125 mph.
If you are worried about losing acceleration due to the "taller" tire....drop the front sprocket on tooth. Generally that is worth a 8 - 10% reduction in gearing that will bring back the acceleration.
If you are worried about clearance the to front of the swing arm with a taller tire the smaller sprocket will give you a bit of chain slack and allow you to pull the rear wheel backwards away from the front of the swing arm.
I am going to try this change on my CB1100 ....when the time comes for a new tire.
Wolfgang
G'day Wolfgang, and welcome to the forum.
I think I'm right in saying the speed limiter is contained in the ECU. If you have it reflashed to remove the rev limiter, you can also have the speed limiter removed. A number of members have done it. Don Guhl Motors seems to be the go to place in the US. If you searched on Guhl, you'd find lots of references.
Just do what Cormanus said and have the limit removed when you have the ECU reflashed. Problem solved. Problem staying solved Smile
(05-23-2017, 08:45 AM)Lord Popgun_imp Wrote: Just do what Cormanus said and have the limit removed when you have the ECU reflashed. Problem solved. Problem staying solved Smile
Talked to Guhl and ECU Unleased...can't do it yet.
What do you mean, Wolfgang? That it's not possible? Or you can't do it for other reasons?
(05-23-2017, 08:36 AM)Wolfgang_imp Wrote: The CB1100 speed limiter can not be removed without disablement of the speedometer.
Wolfgang
Actually, if you do the math, the diameter with aspect ratio of 80 compared to 70 is only 4.28% larger. If you multiply the new diameter x 112 mph, your new top speed is (theoretically) about 116.8 mph.
Confusion is encountered when comparing 70% of 140 and 80% of 140. There's certainly more than a 12% increase with those numbers, but don't forget the 18" wheel between the rubber has NOT changed. And don't forget the sidewall height is measured in metric millimeters, wheel diameter is in inches...
Changing front and/or rear sprockets will have an impact, but that's a discussion for another day...
It's not cheap. Like us, he probably has a budget that won't support it yet.
(05-23-2017, 09:31 AM)Cormanus_imp Wrote: What do you mean, Wolfgang? That it's not possible? Or you can't do it for other reasons?
I sent both companies e-mails asking to have the rev limiter and speed limiter removed. Both said they could remove the rev limiter but not the speed limiter.
I called ECU Unleased to verify they could not remove the speed limiter. They said they had not figured out how to do that ....yet.
Maybe Guhl misunderstood my question.
I will ask Guhl again
LWS
Ridem32 (who's around a bit without posting much) and Motogeezer1949 (who sold his CB to EarsOnWheels) both had their speed limiters removed. I think bearywierdy in the UK may also have had it done. They were all done by Guhl.
Try sending them a PM if you have any trouble.
Geezer reported running 135 mph I believe, after his reflash
  Speed governor drewdavis_imp 4 580 08-27-2024, 05:49 AM
  Looks like the speed limiter is still on the '14. flynrider 38 3,478 06-12-2024, 05:31 AM
  Seen on Ebay. That CB1100 is not cheap... bioman_imp 52 4,605 08-15-2022, 08:13 PM
Last Post: Soxfanjimmy_imp
  Found on Ebay- cheap silver 5-speed LH engine cover PowerDubs_imp 1 277 05-18-2022, 07:35 AM
  Top Speed, 125MPH? HikerToo_imp 46 3,579 06-06-2021, 03:28 PM
Last Post: Rox_imp
  Will riding with prolonged speed limiter damage the engine?? zirconxi_imp 10 2,824 03-15-2020, 03:39 PM
Last Post: zirconxi_imp
  Triumph Speed Twin Obleo 5 591 01-14-2020, 01:15 PM
  Low-speed shimmy HondaJon_imp 24 1,780 11-10-2018, 11:36 AM
  2017 Honda CB1100EX, still top speed / rev-limited? DaSwami_imp 42 3,104 07-22-2018, 05:36 PM
Last Post: MaFiHa_imp
  5 or 6 speed? Gear indicator? PAULIBIKER_imp 27 2,054 04-20-2018, 02:07 AM
