last of the upgrades?
tdbru Offline
Threads: 13
Likes Received: 40 in 22 posts
Likes Given: 11
let's see, I've added a scottoiler, heated grips, fork gaiters, power port, custom seat, paint matched retro racing cowl from chic design, LEDs all around.  done?  nope.  one last thing.
Sent the forks off to racetech for their spa treatment (custom springs, GVEs, reworked internals, etc) and ordered a set of their G3S rear shocks for my 2014 std model.  Got them installed this AM.  went for a 1.5 hour ride this afternoon.  as expected, night and day difference.  Before when I had the preload set enough to get 1/4 travel in sag, the suspension was so stiff that it felt like riding on an old wagon.  felt every tar snake.  and the wheels bounced, which didn't give a feeling of being planted.  corners had too much suspense to be comfortable.  now the ride is firm but compliant.  both high/low speed dampening setup inside.  feels well planted on the road with no, absolutely no bouncing.  small road imperfections the tires simply go over, staying on the road and I don't feel them.  bigger bumps are correctly damped.  caught myself going faster through the corners on this route before I realized it.  bike was so well planted the corners were effortless and low adrenaline.  both the forks and shocks came presetup for the bike + my weight + my riding style from racetech.  All I had to do was to install.  ride was way less fatiguing with the better suspension.  The rear G3S shocks I ordered were the blacked out versions.  Since the shocks were behind my side bags anyway I wasn't too concerned about the looks.  less chrome than factory (none actually) but if you like the blacked out look, there it is.  Shock preload linearly adjustable with the preload collar and the lock collar.  rebound adjustable too.  but that came setup for me from racetech so I didn't have to bother my neighbor with helping me to measure sag.
put a big wide smile on my face.  Highly recommended if you're frustrated with the stock suspension.  One really doesn't realize how bargain basement the stock suspension is until you've ridden other bikes where they have top line adjustable suspension.  It spoils you.
I think I'm done now with modifications.  bike getting an oil change after the ride.  letting it drain while adding this thread.  Only thing left to do now is to add miles & smiles.
-tdbru
Attached Files Thumbnail(s)
09-26-2025, 05:23 PM
Uncle Sixer Offline
Bloomsburg, PA, USA
Threads: 9
Likes Received: 19 in 8 posts
Likes Given: 8
RE: last of the upgrades?
Sounds great. I have the kit to install the cartridge-emulators or whatever they call it in the front this winter, but the rear is really a bigger problem with way too much compression damping (my opinion) I have the shocks on the softest preload and the rear is still horribly harsh on certain bumps.
Glad to hear what a success you had with the suspension upgrade!
2014 CB1100
ECU Flash
Delkevic Exhaust System
Ikon Shocks
Race Tech Gold Valve Emulator
SF Riding Fork Brace
Bridgestone Battlax T32 FR/RR
NOCO LiFePO4 Battery
09-26-2025, 07:40 PM
tdbru Offline
Threads: 13
Likes Given: 11
Uncle Sixer,
I'd highly recommend the suspension upgrade.  made a day and night difference.  I agree with you, that before I did the suspension upgrade, the compression damping was very harsh.  I felt every tar snake on the road.  Now with the GVEs and the other internal upgrades to the forks, and the G3S shocks in back, firm ride but compliant.  seems to have both high and low speed dampening now.  tires stay stuck to the road.  but all the small road irregularities are not being transmitted to the sprung weight.  Good luck with the fork internals this winter.  I decided by the time I bought all the specialty tools to do the forks myself, I'd have over half the upgrade price into just all the tools.  So I got lazy and just sent the forks off to RaceTech and they had them turned pretty quickly.
Best to you,
-tdbru
09-28-2025, 07:50 PM
dino2000 Offline
CA
Threads: 1
Likes Received: 6 in 3 posts
Likes Given: 1
Just off the phone w/ RaceTech, shocks on order. Did they ask you to fill out a Swingarm Geometry Form? If so, do you still have it? I'd like something to compare my measurements to and we have the same bike. Thanks either way!
2009 Kawasaki GTR 1400
2014 CB1100
2017 Suzuki Van Van 200
2022 Kawasaki KLR
12-03-2025, 01:32 PM
tdbru Offline
Threads: 13
Likes Given: 11
Dino2000,
they said they had the CB1100 on file so I didn't have to fill out the swingarm geometry form. the person I talked with at RaceTech was Sydney Ruge.
Good luck!!
-tdbru
12-04-2025, 09:03 PM
  Performance upgrades. Motomike7_imp 52 4,041 04-02-2023, 10:22 AM
  Time for performance upgrades, like use some tips. FLYTYM_imp 26 2,065 04-02-2021, 01:57 AM
  Horn Upgrades pekingduck 0 238 10-08-2018, 09:18 AM
  Two Worthwhile (IMHO) Upgrades glenncal1_imp 9 879 07-03-2018, 11:32 AM
Last Post: use2b_imp
  ECU and airbox upgrades advice appreciated R748_imp 7 711 05-24-2017, 04:01 AM
Last Post: Gumby 1100_imp
  2015”Upgrades” CB4ME_imp 8 769 12-05-2015, 01:27 AM
Last Post: ChipBeck_imp
  Renthals road highs? Bar upgrades??? jaked89_imp 4 445 11-28-2015, 06:55 AM
  Pic's of upgrades Tranahan_imp 9 576 09-19-2014, 10:56 PM
Last Post: redbirds_imp
  Some Cosmetic Upgrades dagersh_imp 10 670 12-01-2013, 11:24 AM
