A question about handlebars.
I’m going to replace my bars with a set from Renthal. My question is are these aftermarket bars narrower than the stock OEM bars and can the bar ends be removed without affecting the bar weights? Its so cramped in my garage with my car in there a narrow handlebar would really help. I’m looking at a low handlebar with a 7/8 OD.
The bar ends come off easily without messing with the weight in the bar. Just remove the screw and the bar end comes off in your hand.
Others will have to chime in about after market bar width, etc.
If you go with a new Renthal bar, or any other aftermarket bar for that matter, you might want to check out this thread: http://cb1100forum.com/forum/showthread....hlight=gap . The holes in aftermarket bars for the switch housing locating pins may ( or may not ) be slightly off position, or slightly too small to fit the pins. Probably easy to correct if necessary, but just something to be aware of.
(06-10-2018, 04:05 AM)2017EX_imp Wrote: If you go with a new Renthal bar, or any other aftermarket bar for that matter, you might want to check out this thread: http://cb1100forum.com/forum/showthread....hlight=gap . The holes in aftermarket bars for the switch housing locating pins may ( or may not ) be slightly off position, or slightly too small to fit the pins. Probably easy to correct if necessary, but just something to be aware of.
I know I will have to drill a new hole for the locating pins,no big deal.
  Changing handlebars Spontini_imp 7 678 06-10-2020, 01:34 AM
  Just got my new Flanders handlebars,did I get a set too short? FLYTYM_imp 4 414 07-11-2018, 08:16 AM
  Looking to borrow a set of stock 2014 standard handlebars. FLYTYM_imp 0 188 06-10-2018, 03:18 PM
Last Post: FLYTYM_imp
  2014 DLX handlebars higher? the Ferret 12 752 05-23-2014, 03:04 AM
Last Post: Papa Weeley_imp
