Threads: 1
Is this normal for CB1100? I was pumping gas in at gas station with bike on center stand. Started with 1 bar left on fuel indicator. It took about 2 gallons and then pump’s auto sensor thought it was full. It wasn’t. Pulled back on the pump’s hood by hand and added another 0.4 gallons. I’m watching fill level and it looked full so I stopped pumping. After a couple of seconds, gas seemed to settle in tank and there was room again to add more. This repeated a few more times and added another 0.3 gallons. So the tank took 2.7 gallons and the indicator read full bars. That means that at 1 bar, there was 1.2 gallons in tank? And is it normal for a tank to look like it’s full at the cap and then drop in level?
Thanks.
Threads: 28
Which year of CB are you riding?
I know my 2017 EX can take a little bit extra fuel after the pump stops. I fill it until the gas reaches the plate in the filler opening.
If topping up after a ride, remember the hot engine will expand both the tank and fuel. My EX tank moans after it has been topped up after long ride and placed on the center stand in the garage.
Threads: 126
Likes Given: 1
If yours is a '13, i've heard reports from a '13 owner near me of the gas settling into the "sides" of the tank after pumping, allowing you to finish pumping after a short wait. odd phenomena. my '14 doesn't do that.
Threads: 1
Thanks. My CB is a “new” standard 2014.
Threads: 33
Likes Given: 6
Very normal.
Few stations around here have the fume recovery bellows.
When I am in SoCal, usually Death Valley, I pull back on the bellows to allow the pump to operate.
Threads: 129
I don't think it's just the CB. Each of my bikes seem to do that. Honestly, I don't worry about squeezing in the last 0.1 gallon, but they all seem to "look full" before settling and then accommodating more.
Threads: 39
My 13 does this. Add gas, wait for it to settle, add more, repeat ad nauseam. On most occasions I just top off a couple times the ride off. I can't be bothered to waste 3 more minutes trying to get the tank completely full. It's annoying but I guess it's it can be forgiven considering the bike has many pros and very few cons.
Likes Received: 605 in 271 posts
Likes Given: 784
I fill to bottom of neck and let it go at that. I never try and squeeze the last few drops in, because I know I will stop for more before it runs dry.
Threads: 1
Thanks, all. Appreciate the replies!
Threads: 115
I always fill my bikes at home , have two 5 gallon tanks for my bikes and lawn tractor , therefor I have only to tank on the road for longer trips.
