How do you Transport Bike if needed
I am hoping the bikes fits in here, I think it will and I had it built with 4 corner strap rings and wall slots for straps also has a ramp door. Might be able to make a Rally yet if not to far.....
[Image: 867d67acdf23d34912499b0513ca2cd8.jpg]
Two ratchet straps in front from the handlebars down to the front tie down points, two ratchet straps from the rear frame down to the rear tie down points. DO NOT put the bike on either the side or center stands, it must be standing upright. You can get motorcycle chocks at harbor freight to help stand the bike up while installing the straps.
(02-24-2019, 12:38 PM)kennyw_imp Wrote: Two ratchet straps in front from the handlebars down to the front tie down points, two ratchet straps from the rear frame down to the rear tie down points. DO NOT put the bike on either the side or center stands, it must be standing upright. You can get motorcycle chocks at harbor freight to help stand the bike up while installing the straps.
I have no center stand from prior owner installing the Moriwaki header so I am good, Thanks
You're trailering a Harley to the rally?
Sorry, couldn't resist.
(02-24-2019, 12:46 PM)LongRanger_imp Wrote: You're trailering a Harley to the rally?
LMAO sold the Harley....good one though!
I would suggest making the lower triple tree the tie down point in the front over the bars. The weight of the bike can easily bend the bars in an impact.
(02-24-2019, 12:50 PM)chync_imp Wrote: I would suggest making the lower triple tree the tie down point in the front over the bars. The weight of the bike can easily bend the bars in an impact.
point taken, Thanks!
Agree with using the lower triple clamp for tie downs. Also, if possible, I like to anchor the rear wheel to the trailer floor with a small length of rope around the rim/tyre. This prevents the rear end bouncing up and sideways should your trailer hit large bumps at speed.
(02-24-2019, 12:31 PM)Doug Shepard_imp Wrote: I am hoping the bikes fits in here, I think it will and I had it built with 4 corner strap rings and wall slots for straps also has a ramp door. Might be able to make a Rally yet if not to far.....
Hey Doug:
What is the anticipated size of the trailer? 6'x10'?
Two bikes?
Anticipated cost of the trailer?
Manufacturer/seller's website?
Thanks!
(02-24-2019, 02:35 PM)Aussieflyer_imp Wrote: Agree with using the lower triple clamp for tie downs. Also, if possible, I like to anchor the rear wheel to the trailer floor with a small length of rope around the rim/tyre. This prevents the rear end bouncing up and sideways should your trailer hit large bumps at speed.
If you do this, be very careful to clean the wheel first and to wrap it with a soft cloth between the rope or strap and the wheel rim to avoid marring the finish of the wheel. With a chrome steel wheel rim there is not much risk, but with any other finish you can easily leave a mark since the bike will be vibrating and moving a tiny bit.
  Forum display help needed Mixagon_imp 5 590 02-11-2024, 08:16 AM
  New tires needed domenaxe_imp 30 2,221 11-01-2016, 12:51 AM
Last Post: Ulvetanna_imp
  CB1100 observation and advice needed TCBronson_imp 22 1,425 09-28-2016, 07:40 AM
  New tires needed. Best experiences appreciated. Jaychaynes_imp 51 3,228 09-25-2016, 08:04 AM
Last Post: LongRanger_imp
  Help Needed - Odometer & Tripometer Issues goldeneye_imp 17 1,248 06-09-2016, 12:22 PM
  Los Angeles rider needed by superbrace. redReno_imp 9 774 02-20-2014, 01:14 AM
  Good Canadian Dealer Needed HondaJon_imp 0 180 09-14-2013, 06:22 AM
Last Post: HondaJon_imp
  Exhaust ID needed Inline4_imp 3 323 08-05-2013, 07:04 AM
