CB goes in for annual physical with pictures
Lot's of ground to cover in this post.
I think we still have a thread going about trailering a bike and tie down points and so forth. So, I loaded the bike into a small 5X8 trailer I picked up from a friend.
[Image: bb4e14bcfd405348a617615572440382.jpg]
The ramp I picked up at Harbor Freight. I never buy anything mechanical/electrical from them but I will buy things like this. The load rating is for 1,100 pounds. However, when I rolled the CB on it for the first time there was some (in my estimation) significant flex. Afterwards I noticed a few heads off pop rivets laying on the ground.
[Image: 5fe65be3030fe028535296019975c418.jpg]
So I fixed that:
[Image: 4735acb91f49b7d10dadf34ee01cdc5f.jpg]
Then I REALLY fixed it by bolting 3 boxed IRON rails underneath. Heavy as heck now but pretty solid.
[Image: 7b86cc79793d594b8c3625bfa29e5a9e.jpg]
Inside the trailer is a removable chock with 2X6's bolted to it to give it a wider stance for increased stability. Tie downs are anchored into metal sub frame of trailer. I move the chock between my trailers depending on what my needs are at the time.
[Image: ba78e818a8feb4cc986ea1f668ab3359.jpg]
Dropped the CB off for new plugs, valve adjustment as required , rear brake pad replacement and brake fluid flush. estimated at $600.
Middle aged Shop tech rolled bike inside the store, on the main floor and said "Never seen one of these before, this is a looker, going right in the place of honor in the middle"
Better shots of bikes they had in there from last time:
[Image: c1220f6477445eadbdf3fb6e0438b4be.jpg]
[Image: 02d57dce8d2ca94ecbe680005cfd13cf.jpg]
[Image: 4171c4b8d76c906be2a330d0aeb0f5b1.jpg]
[Image: af59ddeff96bba45630d89a69509b70d.jpg]
[Image: b52af89c79256371bfe7f817160763a0.jpg]
Also dropped K&H seat off at upholstery shop and waiting for them to call back on what repair costs will be on the seam that's separating.
Frulk: I like your 5'x8' trailer coverage. Thanks for the details. The ramp ordeal was particularly interesting. What was your pull vehicle?
This isn't Garrett Honda in Nephi, is it?
Nope. Moto Station. Kind of a specialty shop. That I understand they have mechanics on staff full time and when a specialty bike comes in they call those members that know how to work on them. They took care of my Guzzi and seem to be pretty competent. Mostly guys in their late 30's/mid 40's that I've seen. They have bikes in there that are very race oriented and probably run on track days at Miller Motorsports park or whatever it's called now. Numerous Ducs, some Beemers etc. sitting around.
GO asks "What was your pull vehicle?"
Full size pickup. 32 Valve V8. Truck doesn't even know trailer/bike is back there.
However, as light as that set-up is you could pull it with a small SUV/sedan no problem.
(03-22-2019, 07:06 AM)Frulk_imp Wrote: Nope. Moto Station. Kind of a specialty shop. That I understand they have mechanics on staff full time and when a specialty bike comes in they call those members that know how to work on them. They took care of my Guzzi and seem to be pretty competent. Mostly guys in their late 30's/mid 40's that I've seen. They have bikes in there that are very race oriented and probably run on track days at Miller Motorsports park or whatever it's called now. Numerous Ducs, some Beemers etc. sitting around.
Thumbs Up Awesome, thanks.
(03-22-2019, 05:17 AM)Frulk_imp Wrote: Lot's of ground to cover in this post.
So I fixed that:
You have any side shot of the trailer?
2014 Honda CB1100 DLX
2002 Honda CB750 Nighthawk
Here you go. Very small and light unit. There's enough headroom that you can ride the bike in sitting on it.
[Image: b494cca3c77ffbc2b0c430237050b435.jpg]
Did you account for bi-metal (dissimilar metal) corrosion when you attached the iron to the aluminum?
If not, I suspect an oak, birch, ash (thinking inexpensive hardwoods here) would add enough strength and remove the corrosion problem. And weigh less to boot!
A thrid (sp error on purpose - long story) option: Rivet and bond some 18ga aluminum sheet to the bottom of the ramps (think the bottom web of your I beam) to carry the tension loads.
Or get a lighter bike......ROFL
Bi-metal corrosion? That's a thing Rboe? I struggle with Pilsner vs. Lager on most days.
All seriousness aside. I have three trailers currently and am looking to cull the pack by selling this one and another small open trailer. Looking to end up eventually with my current 7X14 flatbed for atv's, hauling stuff to the dump etc. and an enclosed 6.5X14 for the bikes with a rear drop gate and side door.
Google galvanic corrosion for details.
  Pictures of every 'DLX' style tank color / country options? PowerDubs_imp 20 1,753 02-26-2021, 01:53 AM
Last Post: jimgl3_imp
  Pictures of my CB when she was new well tuck in the shipping crate 17-CB-002 7 661 08-18-2020, 09:50 AM
  Starlink pictures max 3 444 03-25-2020, 06:28 PM
Last Post: noroomtomove
  Looking for some pictures of RS turn signals. FLYTYM_imp 3 344 06-18-2019, 08:31 PM
  Bikes, Brats, and Bread with lots of pictures Frulk_imp 11 804 03-14-2019, 03:17 AM
Last Post: jitaylor_imp
  Can somebody help a moron posts some pictures? FLYTYM_imp 42 3,530 03-13-2019, 09:39 PM
  Who can post a few pictures for me? FLYTYM_imp 6 654 11-20-2018, 09:57 PM
  A Bunch of Random Pictures Frulk_imp 8 621 10-16-2018, 12:30 AM
  Pictures of my hot new girlfriend ManInBlack_imp 14 949 08-06-2017, 01:53 PM
Last Post: flynrider
  Bad Accident - Pictures CB4ME_imp 44 2,564 10-11-2016, 05:18 AM
Last Post: feralchimp_imp
