Ran into some trouble with bar risers
scott will_imp Offline
Threads: 9
I had a chance to install my gen mar universal bar risers, everything went smooth, how ever when I angled the bars back , the controls ,, brake and clutch resevoirs were angled down, loosened everything up and adjusted . The left bar control for signals , brights , etc has to be rotated to clear the clutch for long pulls , this part is still loose . It is two pieces with two screws. Im not sure if it had loc tite on it originally. Doesn't look like anything on bar underneath, no residue, both screws can tighten all the way and it still has some play.
Any help is appreciated. Thanks
10-05-2013, 12:23 AM
CIP57_imp Offline
Threads: 68
RE: Ran into some trouble with bar risers
(10-05-2013, 12:23 AM)scott will_imp Wrote: I had a chance to install my gen mar universal bar risers, everything went smooth, how ever when I angled the bars back , the controls ,, brake and clutch resevoirs were angled down, loosened everything up and adjusted . The left bar control for signals , brights , etc has to be rotated to clear the clutch for long pulls , this part is still loose . It is two pieces with two screws. Im not sure if it had loc tite on it originally. Doesn't look like anything on bar underneath, no residue, both screws can tighten all the way and it still has some play.
Usually there is a small hole in the bars and a tit on the controls to set for movement. When you rotated you may have moved out of the set position. I have not looked at mine, maybe someone who has had theirs off can comment.
PS: When i put risers on my ST i had to cut the stop either on the brake or clutch master cylinder to get more rotation.
10-05-2013, 12:33 AM
  VOIGT Risers Duderino_imp 3 418 11-23-2024, 01:09 AM
Last Post: Obleo
  Handlebar Risers?? bubblerboy64_imp 16 1,364 07-16-2022, 06:04 AM
Last Post: calipo223_imp
  ROX Risers and longer brake line? MrBob_imp 3 405 06-14-2021, 12:19 AM
Last Post: MrBob_imp
  Rizoma risers on the cb1100 Zee9_imp 20 1,460 05-28-2021, 02:20 PM
Last Post: Zee9_imp
  HANDLEBAR RISERS - is really necessary??? Alfgaxatico_imp 19 1,220 12-16-2020, 10:40 PM
  Handlebar risers johan_imp 1 216 05-26-2019, 01:08 AM
  No more GENMAR risers so now what options? Skypilot_imp 21 1,502 05-08-2019, 12:34 PM
Last Post: WRXer_imp
  handlebar risers terrydlargo_imp 20 1,442 04-02-2019, 10:54 AM
Last Post: flynrider
  S W Motech Risers redbirds_imp 6 679 11-25-2018, 04:40 AM
Last Post: jtopiso_imp
  Pullback risers el duque_imp 19 912 05-19-2018, 10:45 AM
Last Post: jimgl3_imp
