SuperSprox Installed
The Spaceman_imp Offline
Threads: 42
The SuperSprox hybrid (aluminum/steel) sprocket arrived early. Here are some photos of it installed. Obviously with only 3k miles on the CB I didn't replace the OEM for wear; frankly I did it because I think the SuperSprox part really adds to the bike's looks.
A few tips for installation:
You don't have to remove the caliper to remove the rear wheel, but it helps to put a big zip-tie around the hydraulic line receiver and the rear shock to hold it in place. If you place the tie right, the caliper won't move at all. Don't forget to spread the pads back open to make reinstalling the wheel easier.
It's really easy to ding the wheel on the caliper when removing it. It's a very tight fit; take your time or draft an assistant to help if you can find one.
The spacers on both sides of the wheel will probably fall out when you remove the wheel. Some grease on them will help hold them in place when you replace the wheel.
Grease the axle shaft! The grease isn't there to make the wheel turn easier; the bearings do that job. BUT, axles are notorious for galling and binding on the spacers if they get dry. I spent a long, hot summer afternoon in the garage beating the axle out of my VStrom because I'd failed to keep it lubed.
As I mentioned above, removing the rear wheel is a very tight fit. I found draining the air from the tire made it just a bit easier to get out.
The sprocket carrier should not drop out of the wheel. If it does, it means the rubber "biscuits" that make the drive-shock control are blown. A new set is cheap (around $35) and will make a big difference in the smoothness of the ride. Mine were fine at 3k, but I'll probably replace them with the rear tire.
10-13-2013, 11:24 PM
silascopathic_imp Offline
Threads: 28
RE: SuperSprox Installed
Can you provide the model number and the price and maybe provide a link to the exact item purchased please?
That looks great!
does it come in other colors?
10-14-2013, 01:11 AM
CIP57_imp Offline
Threads: 68
Looks good, did you go up or down a tooth??
10-14-2013, 01:17 AM
lola_imp Offline
Threads: 18
thanks for the write up. Something to look forward to for the cb's christmas presentSmile
10-14-2013, 02:06 AM
Threads: 42
There is an earlier thread here with the word SuperSprox in the title that has a direct link to the sprocket. Or go to http://www.SuperSprox.com and follow the menus for Honda, 1000 cc / over / CB1100. Easy to find it.
$89.00.
Colors are available but I think they are built on request.
I'm happy with the gearing from the factory so I went with the OEM spec tooth count.
SM
10-14-2013, 04:34 AM
CB4ME_imp Offline
Threads: 183
Looks awesome. Great write-up!
10-14-2013, 08:00 AM
Threads: 42
I was watching Top Gear on the BBC tonight, and they were interviewing Casey Stoner at a track event. At the end of the interview they took some close up shots of the bike he was about to ride. He had a SuperSpox on his Honda!
10-14-2013, 10:52 AM
wildezt_imp Offline
Threads: 9
looks good Spaceman.!
10-14-2013, 12:15 PM
meowguy_imp Offline
Threads: 26
Quote:I'm happy with the gearing from the factory so I went with the OEM spec tooth count.
So, what is the advantage of this sprocket over the OEM sprocket?
10-14-2013, 11:28 PM
Threads: 42
(10-14-2013, 11:28 PM)meowguy_imp Wrote: Quote:I'm happy with the gearing from the factory so I went with the OEM spec tooth count.
It's much lighter and has the same or better lifetime/wear characteristics. Sprockets are unsprung weight, BTW.
It looks really cool.
Casey Stoner has one on his bike.
10-15-2013, 02:22 AM
  Has anyone installed a louder horn? Doug Shepard_imp 36 2,527 01-29-2024, 05:14 AM
  I installed the Emgo Reverse Cone Universal slip on danieljrmurray_imp 2 361 05-15-2023, 04:29 AM
Last Post: 3rd Gear Steve
   Traxxion AR-25's installed... great upgrade!! Sparky80_imp 2 310 10-18-2021, 12:38 AM
Last Post: Sparky80_imp
  Hepco & Becker Luggage Installed CaptainChris_imp 61 3,812 12-12-2020, 11:51 PM
  Anyone installed a radiator cover? bioman_imp 35 3,488 05-18-2020, 12:00 PM
Last Post: TXBikerGuy
  Givi Sport Bag installed on 2017 RS OEM Rack Mitch_imp 17 1,191 07-31-2019, 02:39 AM
  Road Comet installed ! greekcb_imp 10 809 06-03-2019, 06:14 AM
Last Post: glennrcompton_imp
  Installed red side covers on 2013 CB1100 Frulk_imp 15 1,133 10-05-2018, 02:54 PM
Last Post: Desert viper_imp
  Type 2 Handlebars Installed Capo 4 426 09-21-2018, 07:02 AM
  MFW Highway Pegs Installed redbirds_imp 6 564 09-18-2018, 06:41 AM
Last Post: redbirds_imp
