Heated grips
sanoke_imp Offline
Threads: 16
Heated grips
Been debating on whether or not to post this as I don't know if these grips are available anymore but I thought I might as well in case someone is interested. I've always run heated grips on my bikes. The ones I found that worked best were sold by Show Chrome as grips for 1" handlebars. I've used at least four sets of them so far and never had a problem once. The thing I like about them is they have a continuously variable control so you can set the heat to whatever you like.
I had a set that I bought as a spare a number of years ago and finally decided to put them on my CB1100. What I did to make them fit was to cut off the ends with a hacksaw to clear the end weights and to shim up the bars using wraps of nylon non-adhesive self sticking tape. The old grips I removed by cutting them off with a box cutter so as not to damage the throttle sleeve. I then wrapped the nylon tape until I had a snug fit and then glued them on with grip cement. I did the same thing on my Yamaha Maxim and they have held up quite well for over 7 years. The nylon tape has the added advantage of insulating the grips from the bars so you get even more heat.
I paid about $50 for the grips about 5 years ago so if you can find a pair, they shouldn't be too expensive. Far better than what Honda charges for theirs.
Here's a picture:
[Image: 909c1cb50aea571d35a2e9166e2ca371.jpg]
11-15-2013, 09:25 AM
  Fork Gaiters and Heated Grips tdbru 20 2,925 05-02-2025, 11:16 PM
  Spare connectors/Oxford heated grips White Dog_imp 13 1,438 04-18-2025, 10:02 AM
   HEATING GRIPS ICON HONDA ORIGINAL NON-OPERATING CB1100 ex 2015 EUROPE. COMPLAINT TO Alfgaxatico_imp 16 1,805 12-10-2020, 07:35 AM
Last Post: Alfgaxatico_imp
  HEATED GRIP HONDA ORIGINAL - CB1100 ex 2015 Alfgaxatico_imp 9 739 11-21-2020, 09:45 AM
  hand guards and heated grips misterprofessionality 33 2,270 11-16-2020, 10:06 AM
Last Post: mrded_imp
  thicker grips active1951_imp 15 1,163 08-04-2020, 12:55 PM
Last Post: gmike_imp
  Making closed end grips work on the CB Skypilot_imp 6 607 05-18-2019, 10:40 AM
  OEM ONLY HEATED GRIPS peterbaron 4 546 10-09-2018, 10:59 AM
   Good grips for CB1100? Which ones are you all installing? rdtshaw_imp 61 4,201 08-06-2018, 11:47 PM
Last Post: itstuantran_imp
  Threw on Rizoma grips and bar ends. silascopathic_imp 9 769 06-01-2018, 02:23 AM
Last Post: Mandrau_imp
