Fitted the NC Plexi 3.
flynrider Offline
Phoenix, AZ
Threads: 28
Likes Received: 6 in 2 posts
Did some highway riding on Sat. with the temperature around 50 deg.
F. After about an hour at highway speed the cold was soaking through. The CB1100 was wearing its summer shield, an NC Deflector DX and I wasn't wearing any special cold weather gear.
I'd already mounted the Plexi 3 on the CB750, as I usually do each winter. I started wondering if that might work for the CB1100 as well. My main concern was that National Cycle does not list the Plexi 3 in their fitment guide for the CB1100, although they do list the Plexistar 2 which is virtually the same shield without the lowers. My guess was that the lowers might not fit behind those big turn signals.
Last night I had some free time, so I pulled the Plexi 3 off the CB750 and tried it out on the CB11. Initially, it was a pretty tight fit behind the turn signals, as expected. I also had to relocate the handlebar mounts to a lower position because the clutch master cylinder was getting in the way of the arm that extends back from the shield.
In the end I did get it to fit, but it was a really tight squeeze. I can see why NC doesn't recommend it. I'll test ride it for a few weeks to see if it works out. I wouldn't be opposed to using a Plexi 2 on the bike, but I really like the lowers that keep my knees warm in the winter.
[Image: f8ce1e83c181c4f56fa19bec3cf46ed2.jpg]
12-09-2013, 11:04 AM
the Ferret Online
Likes Given: 753
RE: Fitted the NC Plexi 3.
Looks good!
We start celebrating around here in the spring when it makes it up to 50 degrees. Time to pull the shields and start serious riding ha ha
12-09-2013, 11:20 AM
rboe Offline
Phoenix, AZ
Threads: 64
Likes Given: 7
Oh man, may have to do that.
12-10-2013, 11:08 AM
flynrider Offline
Phoenix, AZ
Threads: 28
I test rode it to work this morning. Temps were in the mid 40s. Coverage was almost as good as on the CB750 and I was a lot more comfortable at 50+ mph. Everything from mid-shin to the upper part of my helmet was out of the breeze.
The larger instrument cluster on the CB11 was bumping the shield, so I had to adjust the rake forward about 1/4". I also noticed that coverage for my hands wasn't as good. The way it fits leaves the bar ends at the upper part of the area covered by the shield side extensions (see pic).
Overall, I don't think I'm going to run out and buy a Plexi 3 for this bike. The fit is really tight and there's very little room for adjustment. I'll probably ride it for another week or two and see if I change my mind.
12-10-2013, 11:34 AM
rboe Offline
Phoenix, AZ
Threads: 64
Likes Given: 7
When you get a chance, can you take a front on picture (or from the seat?)?
12-10-2013, 12:36 PM
flynrider Offline
Phoenix, AZ
Threads: 28
Will do!
12-10-2013, 02:11 PM
rboe Offline
Phoenix, AZ
Threads: 64
Likes Given: 7
Or better yet, come join us up at The Grotto some Sunday morning. Smile
12-10-2013, 11:46 PM
flynrider Offline
Phoenix, AZ
Threads: 28
Sunday mornings I'm usually flying with my airplane buddies (the first half of Flynrider!)
I took some front and back pics when I was at work today :
[Image: 2c309b303ba5b7c15962a1feb2825e20.jpg]
[Image: d44d29d32680f83999d6a33c5bebca02.jpg]
12-11-2013, 09:41 AM
rboe Offline
Phoenix, AZ
Threads: 64
Likes Given: 7
Well. I'd rather fly too. Smile Thanks for the pics. Worship The protection for the hands and legs looks pretty good. I take it you are still on the fence.
12-11-2013, 01:45 PM
flynrider Offline
Phoenix, AZ
Threads: 28
(12-11-2013, 01:45 PM)Rboe_imp Wrote: Well. I'd rather fly too. Smile Thanks for the pics. Worship The protection for the hands and legs looks pretty good. I take it you are still on the fence.
Leg protection is great. Hand coverage is just OK at speed. The bars sit back and kind of high behind the cutouts (see the top pic). The cb750's bars sit inside the middle of the curved cutout with the lever ends about 1/4" from the shield.
I think I'm going to put the Plexi 3 back on the CB750 and try a Plexi 2. I was looking it over today and noticed that the shield is pushing against the back of the turn signals and I can't adjust it back any farther. Overall, I like the coverage, but the shield just doesn't fit the bike well.
I had high hopes when another member posted a pic of an original model Plexifairing on his CB11. I guess the older ones had a slightly different shape.
12-11-2013, 05:18 PM
  Anyone fitted Rizoma iRide turn signals to CB1100EX? Richard_imp 8 799 05-20-2020, 09:58 PM
Last Post: Richard_imp
  CB1300 Aluminum three-point type of security rod, fitted 2014CB1100 Good protection jp4141432_imp 2 434 09-26-2016, 08:56 PM
Last Post: jp4141432_imp
  Pirellis fitted Pterodactyl_imp 27 1,530 02-05-2016, 03:48 PM
Last Post: Pterodactyl_imp
  Shad saddle bag fitted ninjapura_imp 1 181 10-20-2014, 05:01 PM
Last Post: Ridem32_imp
  Plexi 2 windscreen air charlie_imp 13 891 08-29-2013, 01:10 PM
Last Post: rboe
