does slip on exhaust affect performance
fredkb_imp Offline
Threads: 30
Hey everyone. I am wanting to add a little growl to my exhaust sound. I am not interested in performance gains, only a little rumble . If I install a slip on muffler, staintune, yoshi, etc.. will I lose any low or mid range power if everything else is left stock. Thanks for any input. I dont think this topic has been addressed before, if it has, my apologies.
Sent from my SAMSUNG-SGH-I337 using Tapatalk
04-07-2014, 10:03 AM
CB4ME_imp Offline
Threads: 183
RE: does slip on exhaust affect performance
(04-07-2014, 10:03 AM)fredkb_imp Wrote: Hey everyone. I am wanting to add a little growl to my exhaust sound. I am not interested in performance gains, only a little rumble . If I install a slip on muffler, staintune, yoshi, etc.. will I lose any low or mid range power if everything else is left stock. Thanks for any input. I dont think this topic has been addressed before, if it has, my apologies.
A lot of us have Staintune exhaust - high quality, great sound, high price. Others has a other brands. Check the accessories section of the forum.
I didn't notice any changes with the slip-on until I freed up the intake side. Then there was noticable gains in performance.
I don't believe you see any performance losses in any RPM range and will probably gain a little across the board. But you may not notice signifiant gains. The CB will definitely sound better.
04-07-2014, 10:18 AM
wildezt_imp Offline
Threads: 9
i have a moriwaki slipon with a custom tuned PC V..its butter
04-07-2014, 02:43 PM
shdwghst457_imp Offline
Threads: 22
Pardon my ignorance on the subject, but how exactly does a slip-on work? I'm assuming it uses the stock header. What's the installation difficulty?
04-07-2014, 11:55 PM
Sfomoto_imp Offline
Threads: 19
I added an K&N air filter and Staintune. I think it made a big difference in sound and performance. Thumbs Up
04-08-2014, 12:36 AM
Threads: 698
Likes Received: 625 in 279 posts
Likes Given: 792
(04-07-2014, 11:55 PM)shdwghst457_imp Wrote: Pardon my ignorance on the subject, but how exactly does a slip-on work? I'm assuming it uses the stock header. What's the installation difficulty?
It is a differently shaped or sized or restricted muffler. Clamps to the stock head pipe in front down by the footpegs, bolts in back similar to the stock unit or with a extended mounting bar for some of the lower slip ons.
Compared to the stock unit, it usually makes more noise, can make more or less hp, always weighs less.
04-08-2014, 12:41 AM
Threads: 22
On the CB1100, does it involve cutting the stock exhaust? I'm not a fan of "permanent" mods. At that point I would keep the stock exhaust intact and maybe replace the whole system.
04-09-2014, 07:09 AM
Tortuga_imp Offline
Threads: 23
No aftermarket 'bolt on' end can or slip on exhaust pipe has ever needed any cutting away of the standard header pipes. Hence the names.Wink
04-09-2014, 07:24 AM
Sfomoto_imp Offline
Threads: 19
I added the Staintune slip on exhaust. I wrote a short review about it here:
http://sfomoto.blogspot.com/2014/05/i-de...-my_1.html
It's smaller, lighter, and deeper sound. I upgraded to a K & N air filter to increase air flow. Only took about an hour.
05-03-2014, 03:43 AM
The Spaceman_imp Offline
Threads: 42
Loosen one clamp. Loosen and remove the hanger nut and bolt. Slip the original can off. Slip the new can on. Insert hanger bolt and tighten nut. Tighten the clamp.
It's just that fast, just that easy, with Kraft Miracle Whip.
05-03-2014, 08:40 AM
  need help installing slip on exhaust nw suburb, IL jm0327_imp 18 1,697 10-25-2024, 12:12 PM
Last Post: iamheero_imp
  Exhaust system/slip-on johnny_elpino_imp 26 2,181 05-26-2023, 01:06 AM
Last Post: kzoorue_imp
  Arrow Slip-On Thoughts le_penseur_imp 84 5,804 05-15-2023, 05:20 AM
Last Post: mrded_imp
  Performance upgrades. Motomike7_imp 52 4,180 04-02-2023, 10:22 AM
  delkevik slip on mufflers outback_imp 4 561 10-14-2021, 12:44 AM
Last Post: outback_imp
  Delkevic Muffler slip-on wgscheib_imp 2 378 06-08-2021, 01:48 AM
  Arrow slip on mufflers DougsZ28_imp 15 1,289 05-13-2021, 04:09 AM
  Time for performance upgrades, like use some tips. FLYTYM_imp 26 2,171 04-02-2021, 01:57 AM
   Over racing slip on spartanheed_imp 7 794 07-05-2020, 08:33 AM
Last Post: Cobalt23_imp
  Busso Slip-On and DLX Seat Cobalt23_imp 15 1,037 07-02-2020, 07:51 AM
