Alternative sprockets
My 2013 cast wheel 5 speed has 18T front and 39T rear sprockets as standard.
I would like to change the gearing to get more mph per 1000rpm ( so bigger front/smaller rear ) but I cannot identify any UK source for a 19T front or a 36T rear sprocket ( there are any amount of sprockets going smaller front/larger rear ! ).
I was looking at a cb1300 front 19T sprocket on ebay. Does anyone know if this will fit ?
Thanks
I got my 19 center from some outfit called Chris products/PBI. Dropped at lest 200 rpm from my cruising speed of 65mph. And I believe I get 8 miles more from a tank of gas.
For my '13/5 speed, I only replaced front OEM 18T with 19T sprocket, and you will have to grind down a "C" shape metal steel plate. I never touched my rear sprocket, but in your case...??
See this thread:
http://cb1100forum.com/forum/showthread....T+sprocket
and there are a few more, use Forum's "search" option
Thumbs Up
  Alternative for CB1100 talk pdedse 1 308 12-31-2024, 07:54 AM
  Do you use Facebook? (post-forum alternative) Nemo_imp 57 5,121 10-11-2022, 01:44 AM
  The most bike-friendly drivers in my area - alternative power Gone in 60 18 1,750 10-15-2019, 06:33 AM
  Pirellis, Sprockets, Chain, Front Calipers, Pads and Ducks. Pterodactyl_imp 6 647 08-10-2015, 09:45 AM
Last Post: Pterodactyl_imp
  Efficient Alternative to Backpack Carry linuxology_imp 8 1,154 03-24-2015, 08:38 PM
  Alternative tank cbsheep_imp 11 1,035 07-27-2013, 05:11 AM
Last Post: 2013 CBXX_imp
