 Renthals finally installed
Mikey350D_imp Offline
Threads: 4
[url=http://s742.photobucket.com/user/Mikey350D/media/CB1100/CB_renthal.jpg.html][Image: 712de7680fe214161c67739ff5fe7049.jpg]
Finally stopped riding long enough to install Renthal low-rise bars
Drilling the holes didn't go exactly as planned.
Had to oversize the holes a bit, and found the "pins" in the switch clusters do a majority of the anchoring. Wrapped some electrical tape at clamping surfaces to keep things tight.
Choose gold color due to impending Ohlins upgrade.
Pros:Smile
I like the look and the more aggressive riding position.
Cons:Sad
Bars are shorter than stock bars, so brake line and throttle line rubbing on head light housing. Brake side mirror is farther inboard now.
They do put more stress on forearms and hands, probably not great for long range stuff.
Had to buy Renthal bar ends (35$Wink,
Overall, I really like the look, so they're a keeperBig GrinSmile
06-27-2013, 02:11 PM
Ack-CB11_imp Offline
Threads: 46
RE: Renthals finally installed
Those look great. Feel any less vibrations going to aluminum?
06-27-2013, 02:33 PM
Threads: 4
Yes, I think they are a little more forgiving than stockers.
The first day bothered my hands and forearms, but since then no problems, did 5 hours the other day with no discomfort.
07-01-2013, 09:13 AM
12cb96vfr_imp Offline
Threads: 27
Looks rad dude, love it!
07-03-2013, 02:22 AM
Riko_imp Offline
Threads: 47
this is the Low, not the Ultra-Low?
silascopathic uses the Ultra-Low
[Image: 9b773ba05e12b28ad0393ae5c846139f.jpg]
But just on view and pictures I dont see much different, though there should be 30mm more height to your bar than his Smile
11-29-2014, 11:03 PM
nhawk7504_imp Offline
Likes Received: 2 in 2 posts
Looks really good. Not as far forward as a superbike bar. My 919 came with Fatbars which are motocross. They were too wide at 32 inches and not enough bend. But the renthal roads are all nice pieces.
11-30-2014, 01:05 PM
Pauley Offline
Walnut Creek, CA
Threads: 14
Likes Received: 14 in 9 posts
Likes Given: 20
Looks nice, Mickey 350D! You wouldn't happen to know the measurements of the bars you installed do you? Rise, pull back, and width?
11-30-2014, 02:04 PM
Kai Ju_imp Offline
Threads: 0
It looks like you turned the risers around, moving the bars forward. Was that to get handlebar to fuel tank clearance at full lock ?
12-01-2014, 02:57 PM
  Has anyone installed a louder horn? Doug Shepard_imp 36 2,866 01-29-2024, 05:14 AM
  I installed the Emgo Reverse Cone Universal slip on danieljrmurray_imp 2 398 05-15-2023, 04:29 AM
Last Post: 3rd Gear Steve
   Traxxion AR-25's installed... great upgrade!! Sparky80_imp 2 358 10-18-2021, 12:38 AM
Last Post: Sparky80_imp
  Finally making some progress............. FLYTYM_imp 19 1,572 07-18-2021, 01:49 AM
Last Post: FLYTYM_imp
  Hepco & Becker Luggage Installed CaptainChris_imp 61 4,157 12-12-2020, 11:51 PM
  Sissy Bar - FINALLY! c-breezy_imp 30 1,868 08-13-2020, 04:14 AM
  Anyone installed a radiator cover? bioman_imp 35 3,840 05-18-2020, 12:00 PM
Last Post: TXBikerGuy
  Givi Sport Bag installed on 2017 RS OEM Rack Mitch_imp 17 1,319 07-31-2019, 02:39 AM
  Road Comet installed ! greekcb_imp 10 912 06-03-2019, 06:14 AM
Last Post: glennrcompton_imp
  Installed red side covers on 2013 CB1100 Frulk_imp 15 1,256 10-05-2018, 02:54 PM
Last Post: Desert viper_imp
