Larger rear sprocket
#81
(07-21-2017, 10:13 AM)beardyweirdy@me.com_imp Wrote: I've done it both ends. One down on the front and two up on the rear.
With my engin mods making just shy of 100bhp it could pull more but I like to be able to use all the engine has. I can rev it out in 4th and still keep my licence... just!
I find 5k rpm + a great and harmonious place to be and usually keep the engine moving.
If I went back a tooth or so then I'd probably be able to get a few more tenths of a second on my 1/4 mile times, but it feels great and that's what it's all about for me.
6th still feels like an overdrive to me but now pulls more keenly when I do need to zip past something.
I like your idea, just to reconfirm:
Do you have the part number for the front pinion & rear sprocket is 206909.
Do you need to replace the original chain?
Will that fit a 2017?
Thanks
Sorry, don't have the front gear part number.
The 42 tooth rear sproket works with the stock chain.
According to JT's chart the 2017 uses the same sproket.
(04-07-2018, 08:06 AM)chync_imp Wrote: I think it’s just a nylon insert in the nut to provide friction isn’t it?
They look like metal clips of some type. They are intregal parts of the nuts.
Does this affect the speedometer at all or is it still accurate?
Should be just fine right? The speed sensor reads the pulser ring on the rear wheel.
Yup- speedo doesn't care.
Thanks guys. I’m going to order one too. Need a new rear tire soon and this will be a good time to replace the sprocket.
You’re going to need an impact tool to get the sprocket nuts off. If you don’t have one, loosen them while the wheel is on the ground and have someone hold the brake. They are on tight!
Alain, here is the front sprocket from Sunstar.
http://sprocketcenter.com/street-sprocke...ocket.html
I was out on the freeway yesterday and found that I am now, with 42 tooth rear sprocket, turning 3500 rpm at 70 mph in 6th. 65, my crusing speed, was at 3200 rpm. Works for me!
Using the chart provided by PD, it is pretty close at 3401 for a 70 mph speed. With the 42 tooth.
Thanks
Thanks
Hi Alain,
I'm sorry I don't have any part no's but can tell you that it fits without having to alter the drive chain.
I think someone else answered the 2017 question...
Installed
[Image: 3ecc8215667999aa13fa564ab8058874.jpg]
  Advice on sprocket replacement? Inhouse Bob 5 557 06-24-2025, 12:57 PM
  Going up 1 on the front sprocket DBM_imp 17 1,309 08-21-2018, 08:36 AM
Last Post: riggies_imp
  Chain and sprocket replacement cost ecka00_imp 2 278 03-16-2016, 07:22 AM
Last Post: Motogeezer1949_imp
  larger tanks on the '14s. Olyrider 1 219 05-12-2015, 05:52 AM
