Yoshimura Full System
CIP57_imp Offline
Threads: 68
RE: Yoshimura Full System
#81
Fuzzy,
What were your total gain with the custom Map and full exhaust? Do you have the dyno print out?
Thanks
09-13-2013, 06:46 AM
GUNFTR_imp Offline
Threads: 4
#82
(09-13-2013, 06:32 AM)Deftquiver_imp Wrote: Are you talking about a carbureted bike dyno tune? I would think that would be much more involved than FI tuning... Carb tuning is wizardry in my opinion.
I am talking about installing a jet kit into dual carbs with the changes already specifically outlined (such as with a Factory Pro jet kit or Dyna Jet kit) but it still taking two shop hours to perform taking everything apart, installing new jets, and then putting everything back together again and test riding to make sure it's right. $200 for two hours of work seems reasonable to me.
I can't imagine that creating a new map could be that much quicker even though it's all electronic... we simply need for the makers of the Power Commander to come up with some off the shelf maps so that it becomes plug and play and the dyno can be left out of the equation except for the sales brochure.
09-13-2013, 06:53 AM
FUZZY_imp Offline
Threads: 18
#83
(09-13-2013, 06:46 AM)CIP57_imp Wrote: Fuzzy,
Thanks
Here are dyno results. Considering stock is about 80 rwhp, not too bad.
[url=http://cb1100forum.com/forum/showthread.php?tid=1002&page=3]http://cb1100forum.com/forum/showthread....002&page=3
silascopathic_imp Offline
Threads: 28
#84
interested in what you use as I was thinking of rejetting mine too
09-13-2013, 07:39 AM
FUZZY_imp Offline
Threads: 18
#85
No re-jetting CB.
09-13-2013, 11:58 AM
Threads: 28
#86
really? Sad
09-13-2013, 11:28 PM
GUNFTR_imp Offline
Threads: 4
#87
I was only comparing the cost of rejetting a carbureted motorcycle with the cost of remapping a fuel injected motorcycle. The CB has no jets.
09-15-2013, 11:06 AM
Oboro_imp Offline
Threads: 16
#88
What is the part number for the center stand stop please and thanks?
09-27-2013, 12:11 PM
Greg_imp Offline
Threads: 8
#89
Fuzzy
You're a early pioneer with exhaust, air and PC.
Are you still running the full Yoshi exhaust, open air intake and PCv?
If so do you mind answering a couple of questions?
1. Is there less noticeable heat compared to stock? I'm thinking like when sitting at a light.
2. Did you install the O2 sensor in the Yoshi pipe or plug the bung hole?
3. Have you noticed anything else unusual that might be related to the modified set-up?
Thank you!
05-03-2014, 04:51 AM
FUZZY_imp Offline
Threads: 18
#90
(05-03-2014, 04:51 AM)Greg_imp Wrote: Fuzzy
Thank you!
05-03-2014, 09:57 AM
  Yoshimura RS3 replacement for an '13 Jurlie_imp 7 698 07-28-2024, 01:47 PM
Last Post: Glockrocks83_imp
  Exhaust system/slip-on johnny_elpino_imp 26 2,232 05-26-2023, 01:06 AM
Last Post: kzoorue_imp
  Yoshimura RSCV Full Exhaust System Stealth128_imp 43 4,047 11-29-2022, 10:38 AM
Last Post: mrded_imp
  Dart flyscreen and a little Yoshimura stain magic 1985CB450_imp 19 1,873 10-24-2022, 04:12 AM
Last Post: 1985CB450_imp
  Installation of a Smart Turn System [No Cut Mod] LayerCake_imp 20 1,888 06-15-2022, 01:28 AM
Last Post: KiowaEagle_imp
  PCV with full exhaust worth getting tune?? gretle_2.0 4 476 05-24-2022, 03:43 AM
Last Post: gretle_2.0
  Arrow full exhaust gretle_2.0 2 361 05-17-2022, 11:38 AM
  Moriwaki 4 into 1 full pipe GS1100_imp 9 754 01-30-2022, 12:59 PM
Last Post: rich_imp
  full delkevic exhaust outback_imp 27 2,175 01-14-2022, 11:12 AM
  Yoshimura RS3 Install. 2013 Kit on a 2014 and sorted the center stand issue! rdtshaw_imp 17 1,376 01-05-2022, 10:54 PM
Last Post: Nibis_imp
