Rubber Lever End Thingies
Likes Given: 789
RE: Rubber Lever End Thingies
Well that may have been the last one then. In 1979 the 550 was replaced with the CB 650 and I believe it had black levers/no rlets.
04-16-2017, 05:06 AM
chandler_imp Offline
Threads: 11
I give up. I just spent almost an hour out there trying to get one RLET on. I read all posts, boiled the RLETs, sprayed a little WD-40 on the lever, used some gloves and paper towels, and tried with all my might to get one on. After a while of sweating, swearing, and my hand cramping up, I split the rubber on one of them. Although this finally allowed me to get it on, I knew it didn't count. I give up. Maybe I'm just not cut out to be cool.
2013 Honda CB1100
04-22-2017, 10:18 AM
Elipten_imp Offline
Threads: 13
Go to the rally and someone will get it on for you.
Sent from my iPad using Tapatalk Pro
04-22-2017, 10:29 AM
Ben70_imp Offline
Threads: 23
chandler- don't tell anyone, this is just between us. Use the lube of your choice, WD-40 is ok, and warm a cup of water for a minute in the micro-wave. Drop them in for a few seconds and fish them out using a needle nose pliers. Then take the pliers, and another pair, and insert them so you can grip and spread open the RLET. You need to hold the pliers backward so you can pull the little guy on away from you, if that makes any sense. Good luck, and remember, don't mention this to anyone. I think the spit and blood method may be the only officially sanctioned means of install.
Ben
04-22-2017, 10:36 AM
mattmcuomo@yahoo.com Offline
Threads: 25
Likes Received: 28 in 8 posts
Likes Given: 5
I just attempted putting some on. I let them sit in the sun for awhile, a little WD and two needle nose pliers, one went on no problem, the other split wide open! Just ordered two more....[Image: ffddc2efb62bb27d13fd5791f99e87b9.png]
Sent from me
04-22-2017, 10:51 AM
Threads: 11
(04-22-2017, 10:36 AM)Ben70_imp Wrote: chandler- don't tell anyone, this is just between us. Use the lube of your choice, WD-40 is ok, and warm a cup of water for a minute in the micro-wave. Drop them in for a few seconds and fish them out using a needle nose pliers. Then take the pliers, and another pair, and insert them so you can grip and spread open the RLET. You need to hold the pliers backward so you can pull the little guy on away from you, if that makes any sense. Good luck, and remember, don't mention this to anyone. I think the spit and blood method may be the only officially sanctioned means of install.
Ben
Thanks, Ben. Secret is safe. Your tip makes perfect sense. Honestly, I felt like some needle nose might be key, but I don't think I read anyone else who mentioned it and, like I said, I'm just trying to do it like the cool guys. I'll have to order another RLET and try again. I'd hate to get one on now and not do the other. No telling what that might do to my handling or fuel consumption.
2013 Honda CB1100
Also, my thumbs are killing me. No joke. I think my thumb nails might be purple by morning.
2013 Honda CB1100
04-22-2017, 10:53 AM
Likes Given: 789
Calling Nemo on the RLET hotline...calling mr Nemo, we have an emergency
04-22-2017, 10:58 AM
Chapomis_imp Offline
Threads: 64
Cornstarch
04-22-2017, 07:27 PM
Lord Popgun Offline
El Supremo RLET Force
Virginia
Likes Given: 142
The journey to enlightenment is not easy for some Padawans.
04-22-2017, 08:12 PM
redbirds_imp Offline
Threads: 186
(04-22-2017, 10:18 AM)chandler_imp Wrote: I give up. I just spent almost an hour out there trying to get one RLET on. I read all posts, boiled the RLETs, sprayed a little WD-40 on the lever, used some gloves and paper towels, and tried with all my might to get one on. After a while of sweating, swearing, and my hand cramping up, I split the rubber on one of them. Although this finally allowed me to get it on, I knew it didn't count. I give up. Maybe I'm just not cut out to be cool.
2013 Honda CB1100
They're hard to place because they don't belong on any bike's levers. In the days of yore, when Hondas were sold with these cursed rubbers, I would cut them off before I took a new Honda home.
I will personally perform the "brit milah" and act the role of mohel for anyone ready to rid their bike of these accursed coverings.
04-22-2017, 10:15 PM
  2014 Shift Lever Extension Modification, Replacement? HeavyMetalMech_imp 12 1,090 08-02-2021, 10:29 AM
Last Post: HeavyMetalMech_imp
  Brake lever guard for track days mrded_imp 17 1,288 05-26-2021, 07:50 PM
Last Post: mrded_imp
  U-Lock Rubber Band LakeWylieJoe_imp 39 2,463 05-02-2021, 04:00 AM
Last Post: LakeWylieJoe_imp
  Little black thingies GIXXERMAN_imp 18 1,189 12-17-2013, 10:40 PM
