Where to tap speed sensor signal?
peterbaron Offline
Likes Received: 620 in 338 posts
Likes Given: 1,057
RE: Where to tap speed sensor signal?
#71
It depends what sensor is attached to these two wires...
popgun , max, SportsterDoc, are we going to run an e-clinicHuh
Generally speaking, without going into details, if there is a two wire pulse generator (N-S) sensor = it does not matter which wire is used as a signal.
In a two (or three) wire hall-effect sensor does mater, signal only.
If I am wrong, correct me please, brain ageing
I need a break with 0.1 amp fuse and VACATION with 200A fuseTongue
07-16-2018, 04:51 AM
egleaves_imp Offline
Threads: 11
#72
I just sent a message to Signal Dynamics asking if they have any insight on this. We'll see if they have anything to add.
07-16-2018, 05:37 AM
max Offline
Threads: 39
Likes Received: 15 in 8 posts
#73
Well in the case of egleaves he may get an interesting answer from sd. ( edited )
In Josh's case if he has a non abs bike it may be ( depending on the level of the signal )possible to have an opto coupler parallel with the sensor and work something with the output to 5 or 12 volts with a resistor in the output and derive a signal from that.
The led in the opto needs 3 volt or so to light up so that would require 0 to 5 volts from the sensor which is doubtful but he could measure that now across the sensor wires and see if he gets 2,5 v dc with a 50 % duty cycle, all this exceeds the scope of the instructions in his manual for the pcv and i think he needs some help from someone that understands what these parts do.
I agree with peter that this is outside what we normally do and must be getting quite boring for the rest of the forum, sooooo.
07-16-2018, 05:53 AM
SportsterDoc Offline
New Mexico
Threads: 33
Likes Received: 43 in 22 posts
Likes Given: 6
#74
My response to egleaves was limited to identifying the wire for a speed signal, as instructed by Signal Dynamics.
I know my limitations (most of the time), thus the suggestion to contact Signal Dynamics and to return the responsibility to them.
As for a signal off a cam position sensor or crank position sensor, my little bit of knowledge is limited to H-D Sportsters (and some Jeep Wrangler) experience:
Sportster crank position sensors are 2 wire units, which may be described as variable reluctance sensors or magnetic pulse generators, etc. They do not have as clean a signal as hall effect, but generally more durable (simple coil). As with the hall effect, they are typically rated -40 C to 150 C (300F).
For 2004-2006 Sportsters, the voltmeter red lead is connected to ICM position 8 and the black lead to ICM position 9.
For 2007-2013 Sportsters, the voltmeter read lead is connected to ECM position 30 and the black lead to ECM position 12.
Note: This is a sine wave and requires the AC scale
While cranking: ~ 0.3 VAC
At idle: ~ 1 VAC
Static: N/A
When your bike is not starting, this basic test will validate a functional CKP or indicate a failed CKP. A failed unit will not provide a signal. However, this is not sufficient to test for a failing unit with inconsistent output.
07-16-2018, 06:37 AM
peterbaron Offline
Likes Given: 1,057
#75
Update for Egleaves and PowerDubas/Josh and others...
...will send some info about your case with huge delay due to no time and other errands Confused, sorry guys
07-23-2018, 09:09 AM
PowerDubs_imp Offline
Threads: 125
#76
No problem Peter.
07-23-2018, 11:50 PM
Threads: 11
#77
(07-23-2018, 09:09 AM)peterbaron_imp Wrote: Update for Egleaves and PowerDubas/Josh and others...
No worries....I'm still looking for my multimeter Undecided
07-24-2018, 02:31 AM
peterbaron Offline
Likes Given: 1,057
#78
NO, YOU NEED DVOM, FLUKE, NOT JUST METER
07-24-2018, 03:30 AM
Threads: 11
#79
Mine is digital. And missing.
It's not a Fluke, but it gets the job done. Well, it used to....
07-24-2018, 03:48 AM
peterbaron Offline
Likes Given: 1,057
#80
WILL see when job is completed.
Popgun can lend you one with 2 propellers and bakelite case..just ask him..Tongue
07-24-2018, 05:08 AM
  wheel swap cad cnc lazer reluctor for speed sensor 1973cb750 13 3,559 10-28-2025, 05:56 AM
Last Post: 1973cb750
  Turn Signal Indicators balkanhound_imp 5 787 04-17-2025, 11:17 PM
  2014 CB1100 Clear Turn Signal Lenses Ngavrielidis1_imp 16 1,822 04-15-2025, 06:23 AM
Last Post: Ngavrielidis1_imp
  Negotiator-S Speed Pulse Modulator? TonyJames_imp 18 2,169 11-14-2022, 04:50 PM
Last Post: rich_imp
  Can someone with a power commander on a 6-speed bike check something for me? PowerDubs_imp 10 1,003 05-15-2022, 11:42 AM
  auto tune 02 sensor outback_imp 18 1,631 03-16-2022, 07:48 AM
Last Post: outback_imp
  Smaller turn signal/running light choices TxRonHarris_imp 33 3,060 07-06-2021, 10:00 PM
  Extra turn signal on dash Mixagon_imp 7 847 06-24-2021, 07:20 AM
Last Post: 17-CB-002
  Turn Signal Relocation Cormanus 11 1,088 12-30-2020, 11:12 AM
  Signal Relocation Ben70_imp 7 865 02-20-2020, 10:22 AM
Last Post: Ben70_imp
