Motogear Titanium Header and TSR Air Funnel
HondaJon_imp Offline
Threads: 53
RE: Motogear Titanium Header and TSR Air Funnel
#71
Don't need the tool to remove the O2 sensor if I go with a Motorgear exhaust, right? Did you pull your O2 sensor wires from your bike after the PCV install or leave them in place?
Correct, you can just leave it in the stock header, but you will need a plug for the sensor bung in the mototgear collector. I'm not sure what thread size it is exactly. I found a bolt in my spare parts bin that fit. And yes, I left the o2 sensor wire on the bike until I changed the header. It's routed really good and won't go anywhere.
As for the spring puller, this is the one I used;
http://www.motionpro.com/motorcycle/partno/08-0065/
01-06-2014, 06:51 PM
lola_imp Offline
Threads: 18
#72
Hondajon, Did you ever get your bike re dynoed?
Will have mine done in two weeks time. thanks to ya'll for information needed, was really helpful.
01-14-2014, 08:23 AM
SanPete_imp Offline
Threads: 7
#73
I've been following this thread and waiting anxiously for the final results. No pressure HondaJon, but since you were going back on the 11th were you able to get it done?
Hope all is well.
01-14-2014, 03:21 PM
Threads: 53
#74
Apologies all about my late reply. I am dealing with six major construction projects that have been taking up most of my time.
We'll, I have bad news, I didn't do the dyno run on the 11th. After several conversation with the owner of FJ motorsports and an e-mail to dynojet, I did not have the confidence that they could tune my bike properly since the speed limiter was always the topic of discussion. I received a refund and am looking for another shop with a dyno that is not too far from me.
I will say that the stock PC V map seems to be working fine given my mods. I pulled the plugs and they all looked OK, maybe a hair on the rich side if anything.
I am really amazed at the variations of the figures of the maps that have be submitted for inclusion on my chart. I would really like to see "SMILERS" map. His mods are pretty darn close to mine.
01-15-2014, 07:38 AM
Deanohh_imp Offline
Threads: 5
#75
There may be guys who are hesitant to give them up for free after paying $200+ to have it done.
01-15-2014, 07:43 AM
Threads: 53
#76
That's true Deanohh, Never thought of it that way.
I will post mine once I find a more experienced shop to make it. Looks like I have a drive in store..
01-15-2014, 06:56 PM
Threads: 53
#77
I just found a map TSR made for use with it's air funnel kit using Google Translate. **ONLY 6 VALUES ARE DIFFERNANT THAN THOSE ON THE PRE LOADED PC V MAP**
5250 - 5700 at 40 and 60 - these six blocks see increases vs the stocker.
You can download it here;
http://shop.tsrjp.com/item/IS00008N00490.html
Here is the full translation
[ Number ] 17200-S65-000
[ Name ] 10-CB1100 air funnel kit
:2010-2013 CB1100 (EBL-SC65) adaptation model
Material , manufacturing method : A2017 aluminum cutting
I have developed and marketed for the purpose of power-up of the CB1100.
The amount of intake air is increased by expanding the diameter ( inside diameter ) to the genuine parts .
Improvement of engine power can be obtained by using both fuel injection controller commercially available , and the exhaust system .
※ 1. Racing parts
※ 2. I use Dynojet power Commander V is in the development of this product .
※ 3. You can not get the effect of performance improvement in this product separately . You must be used with the following parts .
Fuel injection controller
EXHAUST
And renovation of the outside air intake of the air cleaner box .
We recommend the use of our products , " 17325-S54-000 air intake funnel " .
[Manual / Parts List is here
This [(pvm format ) Power Commander V for recommended map data ]
01-16-2014, 10:45 PM
Deanohh_imp Offline
Threads: 5
#78
(01-15-2014, 06:56 PM)HondaJon_imp Wrote: That's true Deanohh, Never thought of it that way.
you could check out the autotune module. You would need to get the stock bung size replaced with one that fits the wide range sensor. (19mm I think). Worked fine on a FZ1 I had.
01-17-2014, 02:16 AM
rmack_imp Offline
Threads: 6
#79
Just installed a tsr air funnel looking forward to trying it in the morning
Have had a auto tune installed for a while so hopefully it does its job will post results
Has any one fitted a set of arrow pipes interested to see what feed back there is on them as I will have a set in 5 weeks
01-17-2014, 08:21 PM
Threads: 53
#80
I ran the snot out of her yesterday with the TSR map and to be honest, I can't tell any difference vs. the pre-loaded one.
CB4ME, you should be OK with either the TSR one or the stocker. TSR adds some fuel to 6 cells, but other than that, no change.
I want to order those TSR stacks, but I really need some English instructions. The install looks pretty involved and I only want to do it once. Google translate only goes so far.
Going to ask Mr. T. if he can make that happen.
01-17-2014, 11:13 PM
  Stock exhaust or aftermarket header? milkmaster_imp 17 1,388 07-20-2023, 04:11 AM
  Air Intake Funnel? Jeeves_imp 9 789 07-17-2021, 02:46 AM
Last Post: Jeeves_imp
  Header coating Brady Bourgeois_imp 6 569 07-30-2020, 08:55 AM
Last Post: Retsel_imp
  Left over part from TSR Intake and Funnel install?? teamvisegrip_imp 5 510 09-21-2019, 10:48 AM
Last Post: teamvisegrip_imp
  TSR Air Funnel Kit kDiqq_imp 27 1,699 08-12-2019, 04:11 AM
Last Post: dUh!_imp
  Techserfu Titanium Exhaust misterprofessionality 19 1,601 09-16-2018, 05:35 PM
Last Post: 736cc_imp
  Moto gears header + BMS R-evo = good breathing itstuantran_imp 1 279 05-20-2018, 08:09 PM
  Over Racing full system titanium for CB1100RS Ban_imp 2 331 10-02-2017, 08:58 PM
Last Post: Ban_imp
  Yosh Titanium 736cc_imp 18 1,069 05-15-2017, 09:27 PM
  Header wrap installed Carguy1959_imp 18 1,275 10-18-2016, 07:43 AM
Last Post: ChipBeck_imp
