Emgo fairing
kennyw Offline
N9PHW
Sultan, WA
Threads: 42
Likes Received: 5 in 4 posts
Likes Given: 3
RE: Emgo fairing
#61
I didn't trim at the horns. It does touch though. I should double check and see if it should be trimmed.
For the turn signals, I put the center of the half circle at 1.5 inches below the centerline of the mounting slot. This ended up being too high and I had to expand the notch. It was probably closer to 1.75 inches as seen in picture 7.
05-28-2016, 02:49 PM
treytexag_imp Offline
Threads: 5
RE: Emgo fairing
#62
Kenny, thanks again, I'll measure closely. Another friendly chap on the forum here named captwb sent me some good go-by's too.
Quick question, what is the material you put in between your gauges and the windshield? It looks like some foam tape of some type?
(05-28-2016, 02:49 PM)kennyw_imp Wrote: I didn't trim at the horns. It does touch though. I should double check and see if it should be trimmed.
05-28-2016, 05:28 PM
kennyw Offline
N9PHW
Sultan, WA
Threads: 42
Likes Given: 3
RE: Emgo fairing
#63
It's camper tape. Foam tape with adhesive only on one side. I had it laying around.
05-29-2016, 01:15 AM
Huladog_imp Offline
Threads: 23
RE: Emgo fairing
#64
Finally got off my lazy behind and finished installing mine and taking a road test.
I'm still impressed at how nice it looks and is built considering the price. Was rock steady at speed unlike my Road Comet which flexed a bit especially when I had the 'touring' windscreen with the flip on the end. Helps that the Emgo rests against the back of the instruments on some silicone weather stripping that I had laying around.
I would say it raises the comfortable cruising speed from 60 MPH up to 70 MPH compared to the Dart Flyscreen I just removed. Can run a steady 80 MPH now. Airflow does hit me about shoulder height, clean air hitting my visor.
I sat up straight to raise my helmet to compare with clean airflow above the fairing and didn't notice any difference so I think the airflow off the Emgo windscreen is pretty smooth.
Don't think this would replace a bigger windshield for touring purposes but it works well as a warm weather wind deflector ..... plus it looks so dang cool!
If you really wanted to boost that airflow over your helmet, I think the Laminar Lip might kick it up high enough. Saving that experiment for some day in the future when I run out of other things to play with on the CB11.
Aloha,
Huladog
05-29-2016, 07:47 AM
kennyw Offline
N9PHW
Sultan, WA
Threads: 42
Likes Given: 3
Emgo fairing
#65
I went back and did a bit more trimming to clear the horns. Turns out I was pressing up against them making them sound funny. Now I have a little extra clearance at the gauges.
[Image: a104e63153e9ef4196fbf484ec7ebd63.jpg]
I also added a washer between the fairing and headlight bracket and changed the bolts out for black finished button heads left over from my Honda rear rack hardware kit.
[Image: 347a9a8b03a8e0ec91d034c1080a41d9.jpg]
[Image: bdfb9fd6b3431bd1213cdfcc5b0f6b2d.jpg]
06-06-2016, 12:58 PM
0011bc_imp Offline
Threads: 8
RE: Emgo fairing
#66
(05-28-2016, 05:28 PM)treytexag_imp Wrote: Kenny, thanks again, I'll measure closely. Another friendly chap on the forum here named captwb sent me some good go-by's too.
you dont need to trim at the horns. just loosen the nut, take a channel locks and bend the horn bracket tab down (not the whole bracket, but just the part that doesnt allow the horns to be rotated down, you'll see) then rotate the horns down a bit and tighten the nut back down.
this tab
not sure if you can tell but my horns are closer together than yours...
and now that im looking at it i need to adjust mine because theyre a bit crooked....
06-06-2016, 09:49 PM
kennyw Offline
N9PHW
Sultan, WA
Threads: 42
Likes Given: 3
RE: Emgo fairing
#67
I like having the horns tucked in and less visible. I did bend the brackets back slightly before getting serious about trimming.
06-06-2016, 11:14 PM
mattmcuomo@yahoo.com Offline
Threads: 25
Likes Received: 28 in 8 posts
Likes Given: 1
RE: Emgo fairing
#68
One thing I wish I did was to paint inside black before installing.....
Sent from me......
06-07-2016, 01:34 PM
Threads: 5
RE: Emgo fairing
#69
If I wanted to paint mine before I fit it, what would you recommend? I've never painted plastic before. I've painted steel and aluminum, and of course wood, but never plastic. Is there a special brand / type of spray paint I should use? Also, color - flat black, or gloss black like the outside?
(06-07-2016, 01:34 PM)MMC_imp Wrote: One thing I wish I did was to paint inside black before installing.....
Sent from me......
06-08-2016, 09:08 AM
kennyw Offline
N9PHW
Sultan, WA
Threads: 42
Likes Given: 3
RE: Emgo fairing
#70
Just look for a plastic specific paint of any brand if you use a spray can. The important point is that the paint needs to remain flexible after it cures so it doesn't crack and flake off.
06-08-2016, 09:36 AM
  power port and Samurider Road Comet Fairing 1 tdbru 9 974 05-04-2025, 07:20 PM
Last Post: tdbru
  I installed the Emgo Reverse Cone Universal slip on danieljrmurray_imp 2 373 05-15-2023, 04:29 AM
Last Post: 3rd Gear Steve
  Batwing fairing ISO Griz53_imp 1 319 01-22-2023, 03:11 AM
  Road Comet Fairing Catbird_imp 47 4,248 08-16-2022, 10:33 PM
  Rebel 500 SE style fairing? LayerCake_imp 0 278 06-12-2022, 09:03 AM
Last Post: LayerCake_imp
  vetter fairing help Canadianredneck_imp 12 1,045 03-31-2022, 12:51 PM
Last Post: rboe
  road comet fairing vfrpaul98_imp 75 5,002 10-21-2021, 02:41 AM
  fairing ? rich_imp 14 1,172 04-22-2021, 02:13 AM
Last Post: 17-CB-002
  Lookey what I got, Emgo Venom Mark ll mvk24_imp 22 1,513 03-26-2021, 12:36 PM
  Emgo fairing capttwb136_imp 20 1,237 03-09-2021, 02:32 PM
