ECU installed
Randy B Offline
Palm Bay, Florida USA
Threads: 85
Likes Received: 41 in 24 posts
Likes Given: 123
RE: ECU installed
#61
Reaction time is just that, and has no bearing on QM time. The only time it comes into play is when racing like mentioned above.
11-24-2014, 06:09 PM
Threads: 346
Likes Given: 963
RE: ECU installed
#62
How did you get on Ridem? I got it to work all right. As soon as the ARMED light goes out all you have to do is start moving and it starts recording. Even thought it lets you display the speed in kms, I can't see that it lets you measure 0-100 kph which is the standard measure used here.
11-24-2014, 06:22 PM
Ridem32_imp Offline
Threads: 51
ECU installed
#63
Mine still don't work maybe it's where I live. Way out in the sticks. Just confused because all my other GPS stuff works. I will try it again in a different area. Maybe the satellites not hitting me.
11-25-2014, 09:00 AM
Threads: 346
Likes Given: 963
RE: ECU installed
#64
You can tell if the GPS is working. You get a little arrow (pointing up and to the right) on the top right hand side of the screen, to the left of the battery level. Unless you've somehow turned it off, the GPS works independently of the phone or WiFi signal. But it can take some time for any GPS device to find a signal.
11-25-2014, 09:29 PM
metallyguitarded_imp Offline
Threads: 62
RE: ECU installed
#65
I'm very interested in having this done. Fortunately, I have my VFR to ride while the ECU from the CB is at Guhl's. For those of you more mechanically inclined than I am (that means just about all of you), why was our engine limited in the first place? Are there risks to long-term performance or reliability associated with reflashing the ECU? Also, I have plans to install a Yoshimura RSCV full exhaust. If I have the reflash done first, will there be issues with proper mapping and, if so, what would be the most effective way to address those issues? PC-V? Shop tune? I imagine the wise course would be to install the Yoshi system then have Guhls reflash to take that into account.
Another option ... just leave the bike alone. Haha. Somehow, I think that's unlikely.
11-26-2014, 02:55 AM
Ridem32_imp Offline
Threads: 51
ECU installed
#66
Japan restrict it due to their speed limits. The UK bikes don't have the limiter on them. No harm will be done to bike. If your getting a full exhaust for sure just tell Don and he will include that in the reflash!! I sent him mine over nite and he did mine that same day and over nite it back (2) day service for $375 best mod for the CB1100.
11-26-2014, 03:24 AM
Threads: 62
RE: ECU installed
#67
(11-26-2014, 03:24 AM)Ridem32_imp Wrote: Japan restrict it due to their speed limits. The UK bikes don't have the limiter on them. No harm will be done to bike. If your getting a full exhaust for sure just tell Don and he will include that in the reflash!! I sent him mine over nite and he did mine that same day and over nite it back (2) day service for $375 best mod for the CB1100.
Thanks Ridem32. It sounds like waiting until I've installed my full exhaust is the way to go. That will be after Christmas as I have a lot of people to shop for other than myself. I'm curious as to how he will know what the proper mapping is unless he's reflashed a CB1100 with the same exhaust system. I suspect a dyno tune would be needed. Your thoughts?
11-26-2014, 04:09 AM
Ridem32_imp Offline
Threads: 51
ECU installed
#68
Don knows enough about exhaust that he can get it tuned. If it was me I would still run my 02 sensor. If it's a deluxe model you have 2. But I bet the full exhaust don't have a bung for 02 sensor. Check on your exhaust and call Don before you send it to him. He will know what to do. Don is very helpfull and will let you know what's best.
11-26-2014, 04:37 AM
CIP57_imp Offline
Threads: 68
RE: ECU installed
#69
M,
I have the same exhaust you want to put on and have had my bike flashed with the stock PCV map. I runs great and adds about 8% HP. I recently put in a call to a local tuner and e-mailed him my dyno and A/F ratio charts. There is a bit more that you could get out of a personal tune but not enough he felt would be worth it, we looked at my chart along with a member here who has had there stock bike mapped. If you have Don put the stock PCV map in you'll be happy.
11-26-2014, 05:07 AM
Threads: 62
RE: ECU installed
#70
M,
M,
Very helpful info! Thank you!
11-26-2014, 05:29 AM
  Has anyone installed a louder horn? Doug Shepard_imp 36 2,508 01-29-2024, 05:14 AM
  I installed the Emgo Reverse Cone Universal slip on danieljrmurray_imp 2 360 05-15-2023, 04:29 AM
Last Post: 3rd Gear Steve
   Traxxion AR-25's installed... great upgrade!! Sparky80_imp 2 310 10-18-2021, 12:38 AM
Last Post: Sparky80_imp
  Hepco & Becker Luggage Installed CaptainChris_imp 61 3,811 12-12-2020, 11:51 PM
  Anyone installed a radiator cover? bioman_imp 35 3,488 05-18-2020, 12:00 PM
Last Post: TXBikerGuy
  Givi Sport Bag installed on 2017 RS OEM Rack Mitch_imp 17 1,190 07-31-2019, 02:39 AM
  Road Comet installed ! greekcb_imp 10 809 06-03-2019, 06:14 AM
Last Post: glennrcompton_imp
  Installed red side covers on 2013 CB1100 Frulk_imp 15 1,132 10-05-2018, 02:54 PM
Last Post: Desert viper_imp
  Type 2 Handlebars Installed Capo 4 425 09-21-2018, 07:02 AM
  MFW Highway Pegs Installed redbirds_imp 6 564 09-18-2018, 06:41 AM
Last Post: redbirds_imp
