Motogear Titanium Header and TSR Air Funnel
HikerToo_imp Offline
Threads: 114
RE: Motogear Titanium Header and TSR Air Funnel
#61
Won't Power Commander add the new maps to their website as they become available?
[url=http://www.powercommander.com/powercommander/powercommander_maps_installs_product_buy_options.aspx?mdlyrid=16-040&make=19&model=608&make-n=Honda&model-n=CB1100&year=2013&mk=19&mdl=608&yr=2013]http://www.powercommander.com/powercomma...08&yr=2013
01-01-2014, 02:48 AM
HondaJon_imp Offline
Threads: 53
#62
I assume Dynojet only posts the maps that they actual create and test. This works great on super popular bikes where lots performance parts are available domestically. Unfortunately, this is not the case for our ride.
For example, they have 55 maps listed for a 2008 GSXR 1000.
01-01-2014, 06:12 AM
CB4ME_imp Offline
Threads: 183
#63
Jon -
I received a PCV with stock map last night and installed it today. I "enjoyed" the "quick release" fuel line connector for a good 40 minutes before getting it off. Otherwise it wasn't too bad. I also installed the TSR air funnel.
Has the shop provided an update on your map?
01-04-2014, 07:31 AM
Joola_imp Offline
Threads: 12
#64
(01-04-2014, 07:31 AM)CB4ME_imp Wrote: Jon -
Total PITA for sure, but it was easy for me once I realized I needed to pull the rubber stopper out of the quick release in order to squeeze the 2 tabs.
01-04-2014, 08:37 AM
Deanohh_imp Offline
Threads: 5
#65
I got that part ok, but when it came apart, the plastic tab thing stayed on the tank pipe. Couldn't get it back on until I realized I had to put those clips back into the hose connector side and the rubber on the tank pipe..... Then it clicked together easy.
01-04-2014, 09:08 AM
Threads: 114
#66
Were the weather and roads to bad to test it out?
Sent from my iPad using [url=http://tapatalk.com/m?id=1]Tapatalk
01-04-2014, 09:22 AM
CB4ME_imp Offline
Threads: 183
#67
(01-04-2014, 09:22 AM)HikerToo_imp Wrote: Were the weather and roads to bad to test it out?
No testing for me for a while. My last time out was Christmas day. It was -4 yesterday morning and the 6" of snow on the ground isn't melting. But that's nothing compared to what the mid-west is seeing.
01-04-2014, 11:29 PM
Threads: 53
#68
CB4ME,
I have her scheduled to re-do it on the 11th. Yeah, Quick release my A** .. lol. Give me a hose clamp anyday.
01-05-2014, 09:09 AM
Threads: 53
#69
CB4ME,
I pulled my plugs today to see how they looked with the stock PC V map. They weregood, maybe a hint on the rich side, but it was clear the bike was not lean. You should be OK with the stock map.
Do yourself a favor and order this socket, it is a godsend when removing the 2 inner plugs
http://www.motionpro.com/motorcycle/arti...ug_socket/
01-06-2014, 09:19 AM
CB4ME_imp Offline
Threads: 183
#70
" Thin wall design allows for use in small plug cavities"
Jon - Looks like just the ticket! Also looking at the spring puller tool.
Don't need the tool to remove the O2 sensor if I go with a Motorgear exhaust, right? Did you pull your O2 sensor wires from your bike after the PCV install or leave them in place?
01-06-2014, 09:50 AM
  Stock exhaust or aftermarket header? milkmaster_imp 17 1,400 07-20-2023, 04:11 AM
  Air Intake Funnel? Jeeves_imp 9 801 07-17-2021, 02:46 AM
Last Post: Jeeves_imp
  Header coating Brady Bourgeois_imp 6 572 07-30-2020, 08:55 AM
Last Post: Retsel_imp
  Left over part from TSR Intake and Funnel install?? teamvisegrip_imp 5 515 09-21-2019, 10:48 AM
Last Post: teamvisegrip_imp
  TSR Air Funnel Kit kDiqq_imp 27 1,701 08-12-2019, 04:11 AM
Last Post: dUh!_imp
  Techserfu Titanium Exhaust misterprofessionality 19 1,609 09-16-2018, 05:35 PM
Last Post: 736cc_imp
  Moto gears header + BMS R-evo = good breathing itstuantran_imp 1 281 05-20-2018, 08:09 PM
  Over Racing full system titanium for CB1100RS Ban_imp 2 336 10-02-2017, 08:58 PM
Last Post: Ban_imp
  Yosh Titanium 736cc_imp 18 1,072 05-15-2017, 09:27 PM
  Header wrap installed Carguy1959_imp 18 1,279 10-18-2016, 07:43 AM
Last Post: ChipBeck_imp
