oil change
#61
Yea Ive had to take a hammer before and beat around the edge to get them off of filters.
Yeah, I was using the wrench because it was still quite hot down there...these damned air cooled engines take forever to cool down in 95 degree heat... I put it on just right, no cranking on it. I like the idea of removing a little inside the wrench to make it come off easier...
BTW, I love my air cooled engine... tick tick tick...
this genuine Honda filter wrench has a 10mm nut welded to the filter cup so it slips into tight places. it does not have a 3/8" square drive. the wrench/socket size is 17 mm hex with the hole in the nut threaded 10mmx1.25 pitch. if the filter gets stuck in the cup you just thread a 10 mm bolt into the welded nut and this pushes out the filter from the cup.it pays to have and use the correct factory tool. Paul.
I put my filters on ½ turn past the gasket touching on all of my vehicles. Never a leak and I don't need a filter wrench to remove them.
When I did my first oil change I had to use the plier type filter removal tool and damn near had to crush the filter to get it off it was so tight.
Channel-locks take off any filter. Yeah filter is crushed but who cares?
It was on there too tight. That's why I care.
Does anyone know if Honda M/C’s leave the factory without oil, and it then becomes the responsibility of the selling dealer to fill it up?
If so, that might account for the variations in the tightness of drain plugs and filters.
The new Cummins 6bt-5.9 diesel I bought for my boat was crated and shipped without oil. When the dealer was just about ready to run it for the first time he called me to talk about what oil to use.
Mike
Honda engines come with oil. They are test run at the factory.
I recently changed the oil and filter on CB1100 and can verify that the same thing happens as it did to Ferret's ST in terms of oil level being high after short ride. The first photo is when I returned home from 25 minute commute from work. The second photo is by service manual's procedure to check oil level: Start bike and idle for 3-5 minutes, shut off engine and wait 2-3 minutes and check level. Both photos are with bike on center stand.
BTW, I had to drain oil after originally changing it because 4.1 quarts had filled sight glass even with checking oil according to service manual's procedure. Both photos are after some oil was drained out.
I find it weird how the oil level changes based on whether you check it after a short ride or by service manual's procedure....
(07-26-2013, 12:35 AM)The ferret_imp Wrote: Honda engines come with oil. They are test run at the factory.
I lot of people believe that motorcycles come partly assembled and that is why some dealers have healthy "prep charges". But after the outer cover is removed, this photo shows how most are shipped to prevent damage.
  tire change Tom_imp 7 733 05-31-2021, 11:37 PM
Last Post: Tom_imp
  First oil change for this heathen koehlerk_imp 67 4,739 02-20-2021, 02:42 PM
  Oil Change interest? Scotty_imp 10 918 09-15-2020, 09:40 PM
  Oil Change Time! Jambo_imp 57 4,112 09-06-2020, 08:40 AM
Last Post: Jambo_imp
  Oil change before/after winter? HikerToo_imp 11 828 02-09-2019, 05:08 AM
  Oil Filter Change: Every oil change or every other? dbarkdoll_imp 22 1,264 04-17-2018, 12:46 AM
Last Post: Knave_imp
  Oil change questions... ride4now_imp 16 1,051 04-12-2018, 02:12 PM
  fork oil change Houtman_imp 4 423 03-12-2018, 08:46 PM
Last Post: Wisedrum
  First oil change SportsterDoc 30 2,322 11-28-2017, 09:24 AM
Last Post: SportsterDoc
  Completed second oil change (DIY) venturer434_imp 5 480 05-11-2017, 07:47 PM
Last Post: Rocky_imp
