MMG Lithium Ion Battery
#61
Just an update on this product...
I bought this mmg lithium Ion battery from Power sports depot on Amazon.com in February of this year and just a week ago I left the ignition on overnight on my Triumph street triple. Obviously the battery was dead and when I took it out of the bike the bottom of the battery swelled up and would not take a charge.
The battery carries a 6 month warranty and was lucky enough to get a replacement. So just a heads up that this battery is pretty sensitive to drainage. I know flynrider was lucky enough to save his when he had a similar experience...
Other than that I've had 8 months so far on my CB1100 same lithium ion battery and its been working flawlessly.
I just replaced my old battery with one of these MMG lithium ion batteries this weekend. Easy swap. I'll see how it holds up.
2013 Honda CB1100
+1 on lithium. Second bike I've used them on. Just replaced the old lead weight with the featherweight lithium.
I have to say though that replacing the battery on the CB1100 was the biggest pain in the arse of a battery change I've ever experienced. Someone needs a tune up to get that design right.
The weight savings are staggering but it did cost $170 vs $99 for the brick.
What made the battery replacement difficult?
Maybe the dealer left the lifting strap off the battery...
(06-26-2017, 11:17 PM)The ferret_imp Wrote: What made the battery replacement difficult?
Hi ferret. The battery came out with a good old tug. The problem I had was there was virtually no free-play in the battery leads when meant it was a struggle to move them out the way when removing the old battery.
Matters were worse when installing the new one as it was extremely difficult to slide the new battery in as the leads/cables (not sure correct term) which connect to the +/- battery terminals couldn't be pulled and moved out the way (no "free play" in them as mentioned above).
Anyway, all done and only minor skin removal from knuckles in the process. Thumbs Up
ahhh gotcha
Thanks for this post and all the comments guys. Just ordered one for my dead CB.
Nothing like bringing an "old" thread back to life: Looks like I need a new charger for my lead acid (typically AGM) batteries. I thought it was this thread were we had an expert on batteries and chargers. Looking for advise and wisdom. I'd like a good one, not sure I could afford an excellent one - but hey, one can dream!
Suggestions?
Look for an Optimate charger , they have different ones from simple to more elaborate ones.
Also many accessories are available from them.
  ABS , speedometer and battery Walter 10 680 05-02-2026, 01:29 AM
Last Post: Walter
  Yuasa Battery Life dave 28 2,328 04-01-2026, 04:44 AM
  LITHIUM BATTERY UPGRADE: Ballistic vs. Antigravity vs. Shorai E11even_Hunnit 15 1,344 02-25-2026, 11:06 PM
Last Post: Sadorphan
  Rattle on right side exhaust / battery CB1100i_imp 4 628 04-18-2025, 02:48 AM
Last Post: CB1100i_imp
  Battery jumper the Ferret 14 969 10-28-2024, 10:58 PM
  CB1100 SA-E 2017 Battery Davidjill_imp 1 254 08-01-2024, 02:33 AM
  Anyone ever use these Noco lithium Batteries? mvk24_imp 20 1,573 03-25-2024, 01:52 AM
  wonder battery The Gecko_imp 58 4,167 02-19-2024, 11:20 PM
  Could old/low battery trigger misfire and engine light? Motorsport3_imp 13 1,057 12-17-2023, 08:41 AM
Last Post: Jgarciajr40_imp
  Replacement Battery dave 54 3,553 02-04-2023, 12:41 PM
