Counterfeit Oil Filters
#61
Today I went to Iron Pony (a huge dealer in Columbus, Ohio) and they only had the D02 version made in China. So I'll just keep my Revzilla D02 filters. The parts dude said if I can find the D01 anywhere I should buy a bunch of 'em. And I will. I have 3 Hondas that all take this filter.
(04-23-2021, 04:34 PM)michael1954_imp Wrote:
(04-23-2021, 04:19 PM)Indypikes_imp Wrote:
(04-23-2021, 04:01 PM)michael1954_imp Wrote: Checked all mine and they are all real. But I have a new one for the Forum. It came in a Honda Box, has black internals, not red, but it is taller than the one shown here that are real. All mine except this tall one look just like the real filters with the 6 on the bottom.
[img[Image: 2bba0dee75087aeaee3fb46c9dd3c0e8.jpg]
]https://i.imgur.com/cc4bU3F.jpg[/img][Image: 2f50a63dc794a1d5125ba39e0ed5a400.jpg][Image: db50b985865de1ef0a2854b608232d57.jpg]
[Image: 9fde6eb49036949498aea644944fb872.jpg]
I sometimes use HiFlo, but notice it looks a lot like a K&N
I tried this one and it works fine.
[Image: 330e72cec4e4d85cca86a649f700e24c.jpg]
At one time Hi-Flo was making filters for K&N. I don't know if this is still the case or not. I'd be curious to know with the recent reports of K&Ns failing here. I've been using Hi-Flo filters on all my bikes for years (with or w/o nut) and never had a problem. I've read on two different oil/filters sights that quality is considered very good.
At one time Hi-Flo was making filters for K&N. I don't know if this is still the case or not. I'd be curious to know with the recent reports of K&Ns failing here. I've been using Hi-Flo filters on all my bikes for years (with or w/o nut) and never had a problem. I've read on two different oil/filters sights that quality is considered very good. I will get a lot of flak for this one, but I still use my K&N's also. I have used them for years, and never had one leak. I do not use them on the Hondas because I have so many Honda filters, or the other two brands I use. I use the K&N and Hi Flo on my Kawasaki, and use only K&N internal oil filters on my Suzukis. I do watch the K&N carefully now each time I ride because of the reported failures here, but still not a leak, yet. I like the HiFlo filters too, and have them for the Hondas also, just have not got to them yet. Guess I bought too many filters a years or so ago.
I would like the Forum to check out this tall Honda Filter. The box has no English on it. The base fits fine, and it apparently has a greater capacity due to its size.
I would like the Forum to check out this tall Honda Filter. The box has no English on it. The base fits fine, and it apparently has a greater capacity due to its size. Michael, does the tall filter have were it was made/made by on the filter itself? The 1000RR references some OEM filters made by Purflux in France, but no pictures. In my searching around, I have not seen one with that obvious difference in height. I guess unless I could find some credible reference to it, particularly if it came from eBay, I would probably be a little skeptical.
I would like the Forum to check out this tall Honda Filter. The box has no English on it. The base fits fine, and it apparently has a greater capacity due to its size. Michael, does the tall filter have were it was made/made by on the filter itself? The 1000RR references some OEM filters made by Purflux in France, but no pictures. In my searching around, I have not seen one with that obvious difference in height. I guess unless I could find some credible reference to it, particularly if it came from eBay, I would probably be a little skeptical. On the filter it says, FILTECH INE, Assembled in USA It has instructions on the filter!...And in 3 languages, one French, English, and I think Japanese. With the code BE06 It really does look and feel legit.
Michael, According to this CB500V Forum post https://www.cb500x.com/index.php?topic=7119.0 , the tall filter BE06 is an older filter. Included in the post is a link to multinationalparts.com which lists it as appropriate for numerous bikes including the CB1100, but that is what they say, and might be different than what Honda might say. Other than that I only found one other web site listing the filter, and it was just one of those sites that lists eBay ads. I think if I was you and wanted to use it, I would talk to the parts guy at your dealer and see what he can pull up on Honda filter BE06 in the Honda parts system. He should be able to tell you if it is a legit Honda part number and whether or not it is appropriate for your bike.
rickcb, is your reason for hunting around for D01 filters that you think there's something intrinsically wrong with the D02, or are you simply expressing a preference for not buying things made or assembled in China?
I'm still trying to figure whether there is any real problem with a D02 filter.
(04-24-2021, 08:23 AM)Cormanus_imp Wrote: rickcb, is your reason for hunting around for D01 filters that you think there's something intrinsically wrong with the D02, or are you simply expressing a preference for not buying things made or assembled in China?
Maybe it's just that I don't like change? But because they are now made in China I feel like it is more likely there will be quality control issues. My brother is a product manager for a company that makes butterfly valves. Their attempts to save money using Chinese manufacturing were diastrous.
I purchased D01 filters and drain plug crush washers last month at a local outdoor power equipment dealer that carries Honda as one if their brands. Several Honda power equipment engines use the same part numbers for these items as their motorcycles. It's a lot closer than my nearest bike dealer and their prices were a little less too!!
I used my last D01 in March. I would not hesitate using D02 going forward, and would consider reasonable third party parts if need be. I don't even replace the drain plug crush washer. The most I got out of a crush washer was maybe eight oil changes before the bike changed ownership. Some of my bikes lost the crush washer, so I didn't bother replacing it. Never had an oil leak, nor a stripped oil pan bolt or mating surface. Everything hand tightened. I don't over-think things. There are other life issues that require that energy.
(04-24-2021, 11:15 AM)GoldOxide_imp Wrote: I used my last D01 in March. I would not hesitate using D02 going forward, and would consider reasonable third party parts if need be. I don't even replace the drain plug crush washer. The most I got out of a crush washer was maybe eight oil changes before the bike changed ownership. Some of my bikes lost the crush washer, so I didn't bother replacing it. Never had an oil leak, nor a stripped oil pan bolt or mating surface. Everything hand tightened. I don't over-think things. There are other life issues that require that energy.
GASP!! You, sir, are doomed!Big Grin
I re-use, but I do file them flat prior.
I just used my first D02 the other day. Before this thread. It was my 15th oil change on the CB. To be honest I did not even look at the packing. Might be red for all I know. As far as crush washers, on this change it fell into the drain pan. I had a new one in my tool box so I used it. As far as I can remember, the one that fell into the drain pan was the original. At any rate when I emptied the drain pan, I retrieved the old one, wiped it off, and examined it. It looked fine to me. Ran my thumbnail across both sides, no defamation or ridge/lip that I could feel. So it went back in the top of my tool box.
  K&N Oil Filters BEWARE!!! davidsargee_imp 150 10,091 01-27-2020, 10:46 AM
  Air Filters BIGGREEK_imp 20 1,403 02-18-2018, 10:50 PM
Last Post: jimgl3_imp
  K&N oil filters .. known issue..FYI the Ferret 13 831 11-24-2017, 01:32 AM
  K&N Filters: use grease when installing Ulvetanna_imp 4 469 06-26-2016, 01:48 PM
Last Post: Ulvetanna_imp
