Gas Mileage
#61
(07-22-2015, 06:59 AM)ish_imp Wrote:
(07-22-2015, 06:48 AM)The ferret_imp Wrote: Is that top gear? The CB is turning like 3000 rpms at 70. Wow
Edit I was wrong it's 3250 rpms
http://cb1100forum.com/forum/showthread....ed+vs+rpms
Yes, that is 6th gear.
Going to try and find some non-ethanol gas for the cb1100, I also heard a wind screen helps the mpg too?
That depends on the windshield. At freeway speeds, my little NC Deflector would add a few mpg, while the big NC Plexistar tended to turn in a few mpg less than naked.
On one leg of my trip today I went 125.7 miles, took 2.5 gallons for 50.28 mpg
This is with me on it, big, wide, and tall with a stuffed backpack, 300 pounds, riding on the highway between 70-80 mph, with wicked cross and headwinds.
Just unreal.
I'm a bit confounded with my gas mileage. I get to anywhere between 120-130 before I fill up, and generally but in about 2.6/7 gallons, putting me in the 50-51mpg range. The problem? My gas light starts blinking around 100mi... Anybody else find the gas meter on the 2013 standard a little wonky? Fyi, I weigh around 145lb, but ride a lil' liberally Wink Only have gas with min10%eth here.
Yes it has been reported many times the gas meter is extremely pessimistic. My suggestion is to use either your a or b ( I use B) for miles on a tank and start going by that and forget the silly meter. you can probably go 50 miles once your last bar starts flashing, but you sneak up on it..go 20 miles and fill up and see how much it takes and reset your b meter then go 30 etc. Eventually you will figure out how far you can go and still have some gas left and use your B meter to tell you that. Hope I explained that so that you understand it. For example on my 13, I could go 180 miles on my B meter from filling up and still have about 1/2 gallon in reserve. I wouldn't wait until 180 to fill up most of the time, usually at 150 but I knew I could go 180 if I had to.
(07-26-2015, 09:55 AM)Dharma_Jones93_imp Wrote: I'm a bit confounded with my gas mileage. I get to anywhere between 120-130 before I fill up, and generally but in about 2.6/7 gallons, putting me in the 50-51mpg range. The problem? My gas light starts blinking around 100mi... Anybody else find the gas meter on the 2013 standard a little wonky? Fyi, I weigh around 145lb, but ride a lil' liberally Wink Only have gas with min10%eth here.
I get varying mileage depending on how and where I'm riding. In town, where I average in the low 40s mpg, it generally flashes at around 115 miles. On the highway where I get around 50 mpg, it usually starts around 135. One thing that is consistent is that when it does flash, I've got just over a gallon left.
It is disconcerting to watch that bar flash for mile after mile. Another nice thing about the 14s with about 65 miles left it starts counting down for you so you know exactly when you'll be pushing lol
Does it display a wee smiley at the moment it says "Ha, ha, ha. Now you have to push."!
It flashes ... " what's wrong with you, I've been warning you this would happen for the last 65 miles".
(this was intended as a joke... it doesn't really do that)
Lol. How very Honda.
(07-26-2015, 11:48 AM)The ferret_imp Wrote: It is disconcerting to watch that bar flash for mile after mile. Another nice thing about the 14s with about 65 miles left it starts counting down for you so you know exactly when you'll be pushing lol
Had that uneasy feeling coming home one evening. I had been enjoying the ride and scenery to the point of not watching the fuel warning blinking at me. Once I'd noticed, the nearest fuel stop was far off and the trip meter indicated over 150 miles. Made the fuel stop running on fumes as the fill-up showed near tank capacity.
  It's a bargain! ... check the mileage Gone in 60 2 382 10-31-2025, 09:00 AM
  Not a high mileage champ, but ...... ohiorider_imp 7 608 08-16-2019, 07:16 AM
Last Post: ohiorider_imp
  gas mileage on the skateboard the Ferret 8 666 04-07-2018, 12:05 AM
   The LOW mileage thread: For those who don't ride much DocRid_imp 17 998 08-11-2017, 12:11 AM
Last Post: jedd_imp
  Does everyone know about the forum mileage spreadsheet? Rolls_imp 2 253 11-28-2016, 12:04 PM
Last Post: Rolls_imp
  Gas Mileage White Dog_imp 18 1,013 09-20-2016, 09:49 AM
  Opinions on "high" mileage bikes Shinchan_imp 21 1,142 05-31-2016, 07:16 AM
   cb1100 forum mileage 2015 Django 40 2,755 02-01-2016, 09:45 PM
Last Post: emptysea
  Some Issues Arise, as the Mileage Adds Up... JustPassinThru_imp 35 1,956 03-31-2015, 05:44 AM
Last Post: nhawk7504_imp
  Mileage game Randy B 22 1,229 10-11-2014, 04:26 AM
Last Post: Randy B
