Gas Mileage
I was just wondering if something is amiss with my 2014 CB1100. The last 3 fill-ups I have been extra careful to be sure I am filling the tank to the same level. I then calculate my mpg with my trusty calculator. It shows 75-79 mpg. WHAT? Don't believe it. I should pay attention to the meter display to see what it shows, but I assume when I zero the mileage, all the displays are zeroed as well. Next fill-up I'll make a point to do this. I was expecting to see around 45-50 mpg as a stretch but not 75. The fuel meter bar seems to be working properly, as well as the speedometer. It is taking less than 3 gallons to fill up--more like 2.5 gallons.
lol well that would be the best on the forum. I have seen members post from the mid 30's to the mid 60's but never in the 70's. Just to make sure you are doing this right, you fill up and zero. Ride x number of miles and fill up again. then divide miles ridden by amount of gas required to refill.
188 miles ridden divided by 2.5 gals to refill would give you 75 mpg.
Doubt you are going 188 miles n your tank but anything is possible I suppose.
Maybe it is the magic one in a million!
Anything is possible, nothing is real.
If it's a 6 gear EX, why not 70 and some mpg
very slowly driven.
My 2013 5 gear CB takes averagely 61mpg
over a distance of 30.000km.
Once on a tour it passes 70.
Well, I always drive the way of beeing aware
of a low fuel consumption.
Maybe the 6th gear creates gasoline wonders.
Wisedrum
I think part of our mileage calculations get thrown off by our optimistic speedometer (and therefor odometers). If I calculate my mileage using the odometer it's different than if I use Google Maps to get the distance (odometer is about +4% compared to true distance).
I guess 75 is possible, but that seems pretty high.
It says in his signature he owns a 2014 std , that would have a 6 speed, but only a 3.9 gal tank.
Maybe the odometer is set to read kilometers rather than miles? Is that possible on a USA CB? I don't have the owners manual handy to check.
EDIT: 75 km/gal = 46.6 mpg
I average about 45mpg between taking it easy and low rpms to dogging it as well. I have gotten 53mpg before tho
(09-15-2016, 08:51 PM)curlyjoe_imp Wrote: Maybe the odometer is set to read kilometers rather than miles? Is that possible on a USA CB? I don't have the owners manual handy to check.
You can't change the Australian odometer to read in miles, but I've a recollection you can change the US model to kms. Why that should be, I don't know.
The model may be wrong, but check this manual at around p.22, http://www.hme-tc.be/TRG_LIB/NM2013/CB11...OM_ENG.pdf
GOOD GAWD! The dang thang was set to kilometers, not miles! How the heck did that happen? I bought the CB1100 in the USA. This explains the high readings. Totally embarassed! Now I have a "Low Mileage" cycle. :-)
  It's a bargain! ... check the mileage Gone in 60 2 410 10-31-2025, 09:00 AM
  Not a high mileage champ, but ...... ohiorider_imp 7 632 08-16-2019, 07:16 AM
Last Post: ohiorider_imp
  gas mileage on the skateboard the Ferret 8 743 04-07-2018, 12:05 AM
   The LOW mileage thread: For those who don't ride much DocRid_imp 17 1,038 08-11-2017, 12:11 AM
Last Post: jedd_imp
  Does everyone know about the forum mileage spreadsheet? Rolls_imp 2 264 11-28-2016, 12:04 PM
Last Post: Rolls_imp
  Opinions on "high" mileage bikes Shinchan_imp 21 1,310 05-31-2016, 07:16 AM
   cb1100 forum mileage 2015 Django 40 3,101 02-01-2016, 09:45 PM
Last Post: emptysea
  Gas Mileage White Dog_imp 123 7,741 09-11-2015, 10:28 AM
Last Post: EarsOnWheels_imp
  Some Issues Arise, as the Mileage Adds Up... JustPassinThru_imp 35 2,064 03-31-2015, 05:44 AM
Last Post: nhawk7504_imp
  Mileage game Randy B 22 1,396 10-11-2014, 04:26 AM
Last Post: Randy B
