'14 Honda Luggage Rack does not fit the '14 Deluxe
RetroSeattle_imp Offline
Threads: 17
RE: '14 Honda Luggage Rack does not fit the '14 Deluxe
#51
Gumby, I sent you a private message with the bolt to bolt measurement (185 mm) and angle (10.4 degrees) of the rack mounting bolts. One thing to keep in mind is that the 2014 Deluxe rack comes with a new steel aft mount for the grab rail that may alter the angle compared to stock.
06-15-2014, 10:18 AM
berck_imp Offline
Threads: 0
#52
(06-15-2014, 10:18 AM)RetroSeattle_imp Wrote: Gumby, I sent you a private message with the bolt to bolt measurement (185 mm) and angle (10.4 degrees) of the rack mounting bolts. One thing to keep in mind is that the 2014 Deluxe rack comes with a new steel aft mount for the grab rail that may alter the angle compared to stock.
Oh, glad you did that, as I totally forgot. The new steel mounts do not change the angle at all. They are identical to the original ones with the exception of a third hole and welded spacer; presumably the change is just for more support. I examined the two pretty closely while I had it apart.
06-15-2014, 10:23 AM
Gumby 1100_imp Offline
Threads: 17
#53
Thanks guys for your data and photos!
Based on what you have provided and what I have measured on my 2014 Canadian, I believe the following to be true:
The 2014 Canadian frame seems to be closer, if not identical to, the U.S. 2013 and U.S. 2014 Base model with grab rails at an angle of approximately 15 degrees. The 2014 Rack, which is made for the shallower grab rail angle of the Deluxe (approx. 10 degrees), would hit my tail light.
I just have to decide now whether to go with the Honda or Givi rack. I'm leaning toward the cleaner appearance of the Honda rack...
Issues: Apparently the 2014 rack crowds the stock seat to the point of making removal of the seat difficult. What about those with the 2013 rack? How is seat removal and installation with the 2013 rack on the bike?
2013 Rack P/N: 08L70-MGC-A20
2014 Rack P/N: 08L70-MGC-N40
06-15-2014, 01:43 PM
berck_imp Offline
Threads: 0
#54
(06-15-2014, 01:43 PM)Gumby 1100_imp Wrote: Thanks guys for your data and photos!
To be clear, in my case it's not the rack that makes seat removal difficult, but the top case.
06-15-2014, 01:53 PM
Threads: 17
#55
My misunderstanding. Now that I look at your third photo again I can see how it is the Shad base plate that is very close to the seat.
I wonder if the GIVI Monolock system base plate would mount any differently?
06-15-2014, 02:02 PM
Elipten_imp Offline
Threads: 13
#56
Honda Rack is no issue on my 2013 for seat removal.
06-15-2014, 09:34 PM
Threads: 17
#57
http://www.hondapartsplus.com/pages/Cata...uct/230217
Here's a great deal on the 2013 Honda rack at $220 U.S., but only if you live in the U.S.
Unfortunately, they will only ship via UPS.
For Canadians, that means at least another $65 in legal shipping charges tacked onto that $220, PLUS another $75 or so in ILLEGAL fees upon delivery that the UPS "brown shirts" add for Duty, Brokerage and another 13% for Canadian taxes.
So much for NAFTA Wink
06-16-2014, 12:34 AM
berck_imp Offline
Threads: 0
#58
Yeah, I think it's an issue with how the shad plate mounts on the 2014 rack. I could probably make it better with some futzing/custom fabrication, but figured I'd try to live with it like this first. According to Spaceman, the sh-29 fits perfectly on the 2013 rack.
06-16-2014, 02:23 AM
12zsawer_imp Offline
Threads: 3
#59
Hi, new to the thread and the forum. The Honda top box listed on Samurider has a note that says "*The price included 2014 Honda CB1100 rear carrier. #08L70-MGC-N40 / 23500yen". Can anyone tell me if that is actually as it sounds? Does the rear luggage rack come with the top box? I would be embarrassed to buy two racksTongue
Thanks for any help!
06-16-2014, 12:44 PM
Elipten_imp Offline
Threads: 13
#60
I would write Mr. T and ask.
06-16-2014, 03:07 PM
  SIDE bag racks for my   2014 Honda CB1100 Deluxe? LucienLeFranc 13 713 07-01-2026, 08:51 PM
Last Post: rdprdp01
  Luggage Racks pekingduck 8 712 06-02-2026, 07:57 AM
Last Post: HondaLou
  Hepco & Becker luggage Nitro_imp 12 1,035 03-20-2024, 03:37 AM
Last Post: Mitch_imp
  Looking for [2014] Honda luggage rack Jollygods_imp 7 838 05-09-2023, 10:30 PM
Last Post: JRM_imp
  Any soft luggage racks compatbile with Deluxe and OEM rack? slackerdeluxe_imp 3 420 09-11-2022, 04:47 AM
  Luggage oldgoat01_imp 127 8,918 05-31-2022, 05:52 AM
Last Post: LayerCake_imp
  Luggage question mach9_imp 2 336 04-17-2022, 10:23 AM
Last Post: mach9_imp
  Hard luggage suggestions? run-tmc_imp 35 2,067 03-28-2022, 09:55 AM
  Luggage Rack Options Yata-Garasu_imp 25 2,394 11-27-2021, 02:13 PM
  GIVI luggage help tod.branko_imp 7 698 09-14-2021, 08:04 AM
