EOT meter for OEM oil cooler
dsinned_imp Offline
Threads: 22
RE: EOT meter for OEM oil cooler
#51
I forgot about the little button on the back. Sounds like you got it figured out. Please let us know how you like it on your bike.
08-01-2016, 09:49 AM
Lord Popgun Offline
El Supremo RLET Force
Virginia
Likes Given: 136
#52
Dsinned, I got it all mounted up. I ordered the silver color and stuck it in front of the big triple tree nub. Looks pretty good. Maybe I can see how it works tomorrow.
08-01-2016, 12:40 PM
dsinned_imp Offline
Threads: 22
#53
Where did you put the temp sensor?
08-01-2016, 11:15 PM
Lord Popgun Offline
Virginia
Likes Given: 136
#54
When I get home I'll look to be sure, but I think, inserted from the back, third row down close to the inside of the right frame down tube. I wanted it close to the inlet at the top and that was pretty close while allowing a good wire run. Hidden and all. The frame tube played a part in where I put it. As you know, it is easy to move it if needed/wanted.
Maybe I'll get another one an put it on the other side of the oil cooler and see what the temp drop is Tongue
08-01-2016, 11:41 PM
dsinned_imp Offline
Threads: 22
#55
I put my sensor on top of the oil cooler, tie wrapped down to make good surface contact. It is located in the upper right hand side and wrapped in insulating material to keep it out of the direct wind stream. On my last ride the highest reading was 225F. It was a fairly warm day and I riding up a steep uphill grade. Of course, the actual temp of the oil (internally) is somewhat higher.
08-02-2016, 12:14 AM
dsinned_imp Offline
Threads: 22
#56
Popgun, have you made any measurements yet?
08-04-2016, 03:18 PM
Lord Popgun Offline
Virginia
Likes Given: 136
#57
Due to rain here I have only ridden it once. I checked and the sensor is in the second row from the top. I was going to ride a few times to see what happens as it heat cycles, but... On the one ride I did, it was about 82F and low humidity. The most I saw was 190 or 195F while stopped at a light. I think while moving at 50mph in 5th gear (around 2800rpm) it was mostly 153 or so to 160-165. On a long stretch it went to ~173. Interestingly, the temp would drop while riding in the shade, then go up some while in the sun. I can't remember all the readings.
It go to 100F or slightly higher in a couple of minutes at initial startup from dead cold.
Like I said, I want to go through some heat cycles and try to remember better. While riding I was thinking I needed the Ferret cam Smile
08-04-2016, 09:41 PM
dsinned_imp Offline
Threads: 22
#58
Did you use some of the sealing compount (provided by TT) to help insulate the sensor inside the fins of the cooler? That might not have been necessary if your 8mm sensor is already a fairly tight fit, so that in that one spot, outside air cannot flow thru that particular slot. Apparently, this is important because a loose fit affects the accuracy of the readout.
While riding other than in stop and go, I typically see readings similar to yours after warm up. In slower moving traffic conditions, the reading will peak over 200F. It is interesting to see the fluctuations in temp depending on how much overall air flow is moving thru the cooler. It also allows you to tell when the engine (via the oil) has fully warmed up; not as easy to do without something like the TT device mounted on your handlebars.
The more expensive TT device (TTV type) I'm using has the same type of temperature sensor input as yours, but also has a battery voltage input, so it has two selectable readouts. The latter is very useful while my bike is parked in the garage to make sure the battery is being properly maintained by a Battery Tender hookup. (I have found that sometimes a BT's green "charged" status LED is NOT always a reliable indicator).
Can you provide a photo of where you mounted your device to the handlebars?
08-05-2016, 02:29 AM
Lord Popgun Offline
Virginia
Likes Given: 136
#59
I can get you a pic this evening. The sensor fit in the slot snugly. I only put the paste (and it wasn't very pasty) in the very front of the oil cooler. Just to block any air through that slot. Maybe should do the slots on either side too?
08-05-2016, 02:41 AM
Lord Popgun Offline
Virginia
Likes Given: 136
#60
dsinned, here is a pic. A crappy cell phone pic, but shows the Trail Tech, my ram ball mount, GiPro gear shift indicator and a voltage monitor. That thermometer is kind of in the way and I have to lean forward to see the Trail Tech, but too bad for me Smile
[url=http://s284.photobucket.com/user/everettmclendon/media/20160805_181007_zps1yksznb0.jpg.html][Image: f6af0d182704840c27576133304b23db.jpg]
I had to take the pic at a weird angle to see the Trail Tech. Kinda makes me dizzy looking at it.
08-05-2016, 09:16 AM
  Foolish or Reasonable: R&G Oil Cooler Guard rdprdp01 2 441 04-14-2025, 05:16 PM
Last Post: deuce17EX
  Foolish or Reasonable: R&G Oil Cooler Guard rdprdp01 11 892 04-11-2025, 02:41 PM
Last Post: rdprdp01
  Soft cooler for Djangos trip Frulk_imp 7 452 06-02-2019, 06:22 PM
  Oil Cooler Guard Chris Goldson_imp 10 842 11-09-2017, 11:41 AM
Last Post: Dvassino_imp
  2013 Meter covers Uberjason_imp 6 477 02-16-2015, 12:32 PM
Last Post: rboe
  chrome meter covers for 2014 Dlx ss2wheels_imp 9 512 05-09-2014, 01:11 AM
Last Post: Ridem32_imp
  Aero Bobbins and Cooler Guard Tyke57nz_imp 5 424 03-02-2014, 01:04 PM
Last Post: Tyke57nz_imp
  Dart fly screen bracket issue with chrome meter covers Elipten_imp 2 224 01-21-2014, 01:07 AM
Last Post: Bayoucityrider_imp
  Chrome Meter Covers Added Guth_imp 10 649 10-13-2013, 01:41 PM
Last Post: wildezt_imp
  Oil Cooler enzo_imp 11 639 09-10-2013, 07:11 PM
Last Post: enzo_imp
