Where to tap speed sensor signal?
Lord Popgun Offline
El Supremo RLET Force
Virginia
Likes Given: 136
RE: Where to tap speed sensor signal?
#51
First I’d try the blue. The white goes to the -
If you don’t get anything, I can put an o-scope on it and see what the pulses look like (yes Max, I bought one just for this stuff).
THIS—I would also suggest that the meter be connected to both wires. Not ground and one wire.
On outboards, when looking at the triggers you have to use a DVA adapter (direct volt amps) that plug into a Fluke DVOM. It actually just a little integrater circuit, a cap, a diode and a resister). The cap has a SLOW discharge time through the resistor so the pulse voltage will charge up the cap as the pulses come in directly to it, and give a voltage reading. Might need something like that on this. So, TLDR, cap has a fast charge time, slow discharge time. Thus, a voltage builds up that the meter displays. RC time and all Wink
07-14-2018, 07:03 AM
peterbaron Offline
Likes Received: 570 in 309 posts
Likes Given: 952
#52
(07-14-2018, 06:56 AM)Cormanus_imp Wrote:
(07-14-2018, 06:18 AM)PowerDubs_imp Wrote: Tapped into the white on the rear speed sensor (changes to green/pink under side cover.)
Put my meter on it, dcv setting, other lead grounded to a screw. Started bike on center stand and put it in first. No reading.
Thoughts?
You need a new meter? Tongue
Cormanus, you are great...I love jokes ..ROFL
(07-09-2018, 10:11 AM)SportsterDoc_imp Wrote:
(07-09-2018, 10:02 AM)egleaves_imp Wrote:
(07-09-2018, 09:13 AM)SportsterDoc_imp Wrote:
(07-09-2018, 02:57 AM)egleaves_imp Wrote: Not yet. I spent too much time doing other things this weekend. Now I'm interested in hearing the results of PowerDubs stab at this wire before I mess with mine.
So, you are admitting that PowerDubs is braver?!
Many people are braver than me when it comes to electrical work. I'm much better at being a plumber. Big Grin
Humor response award to you!
I hate plumbing...dealing with leaks...much rather keep the smoke inside the insulation!
ClapClapClapClapROFLROFLROFLROFLBananaCelebrateExcited..LOVE these statements
...........................Worship .................................
07-14-2018, 07:54 AM
Lord Popgun Offline
Virginia
Likes Given: 136
#53
Cormanus, New meter is funny.
Since neither wire is connected to chassis ground, the fact that he got no reading is not unexpected.
07-14-2018, 08:07 AM
peterbaron Offline
Likes Given: 952
#54
(07-14-2018, 08:07 AM)Lord Popgun_imp Wrote: Cormanus, New meter is funny.
+1...unless he has a magic screw...lol...
Hey, this is not meant to insult anybody...we need to joke around and laugh as we get bit olderTongue
P.S. Popgan and I have a DVON with a twin propeller...if meter stars overheating, a temperature sensor triggers one or both fans...one cools off the meter itself, while the other the overheated circuit...but not everyone can have this meter TongueTongue, right Popgan
Beer
07-14-2018, 08:15 AM
max Offline
Threads: 39
Likes Received: 15 in 8 posts
#55
Josh i like the enthusiasm, well done and welcome to the world of electrical signals.
sorry, my story picked the wrong wire, have to learn to read before posting too quick.Confused
Yougoddascope popgun?Beer
07-14-2018, 08:30 AM
Lord Popgun Offline
Virginia
Likes Given: 136
#56
Max, no way was I going into all that. Josh is getting deep into experimenting here. Maybe it uses Manchester II Bi-phase. I doubt it, I just like saying Manchester II Bi-phase. And Mil-std 1553... or wait, maybe Non Return to Zero. Naaa.
Peter, I don’t have one of those! Need one! Smile Of course, real old time techs like the Simpson 260. No, not the new ones with plastic cases—the old ones in Bakelite cases. Love those things. DVOM just have a so much highter impedance they are much better for most things. I have a few Flukes I use at home. And Flukes at work.
07-14-2018, 09:08 AM
peterbaron Offline
Likes Given: 952
#57
General info::
WSS is active IC hall type sensor and good at temperature and noise characteristic. Digital waveform is produced as tone wheel rotate according as hall sensor principal. Frequency of waveform is change in proportion to rotation of tone wheel and ECU calculate vehicle speed by this frequency
The ECU monitors WSS circuit continuously. Hi - Low voltage = 1.05 - 0.525 V
A direct current is supplied to the WSS by a power source in the input amplifier of the control unit.
In order to protect WSS when measuring output voltage a resistor must be used...(75 Ohms ???? if I am correct)
Do you really think that regular voltmeter will be useful????
[Image: 7d13ac55248ec98ae5f9e505e93db861.jpg]
Agree with Popgun, Max and SportsterDoc, Josh, stop experimenting = I am deadly serious. I don't even know if you should follow installation instruction of the electronic gizmo you bought. I really don't = have no judgement.
07-14-2018, 09:17 AM
Lord Popgun Offline
Virginia
Likes Given: 136
#58
I don’t really understand the need for a 75ohm resister when even a cheap Fluke DVOM has a greater than 10Mohm imput impedance.
07-14-2018, 09:27 AM
peterbaron Offline
Likes Given: 952
#59
No problem with Fluke, you are right Popgun Smile..just do not know what Josh is using..and my info was general
Smile
07-14-2018, 09:37 AM
PowerDubs_imp Offline
Threads: 125
#60
Huh?
I’m going to need to post my greek picture again. [Image: e0766f28eac44c3774c664394b20bc2c.png]
Read post #44 above for what I am trying to do.
Seems a lot of other brand and models of bikes are using the analog input for the gear setting.
Everything I have read said I should be looking for a 0-5v.
So as you guys mentioned above I tapped the green/pink with the red lead, black to a chassis frame screw for ground, dcv setting since I am on a vehicle and not in my house 120v ac.
Yea- I have no idea. What am I missing? Please reference post 44 above. I’m going to bed. Will check back tomorrow. Thanks!!
07-14-2018, 01:42 PM
  wheel swap cad cnc lazer reluctor for speed sensor 1973cb750 13 2,999 10-28-2025, 05:56 AM
Last Post: 1973cb750
  Turn Signal Indicators balkanhound_imp 5 635 04-17-2025, 11:17 PM
  2014 CB1100 Clear Turn Signal Lenses Ngavrielidis1_imp 16 1,437 04-15-2025, 06:23 AM
Last Post: Ngavrielidis1_imp
  Negotiator-S Speed Pulse Modulator? TonyJames_imp 18 1,729 11-14-2022, 04:50 PM
Last Post: rich_imp
  Can someone with a power commander on a 6-speed bike check something for me? PowerDubs_imp 10 751 05-15-2022, 11:42 AM
  auto tune 02 sensor outback_imp 18 1,291 03-16-2022, 07:48 AM
Last Post: outback_imp
  Smaller turn signal/running light choices TxRonHarris_imp 33 2,353 07-06-2021, 10:00 PM
  Extra turn signal on dash Mixagon_imp 7 677 06-24-2021, 07:20 AM
Last Post: 17-CB-002
  Turn Signal Relocation Cormanus 11 802 12-30-2020, 11:12 AM
  Signal Relocation Ben70_imp 7 709 02-20-2020, 10:22 AM
Last Post: Ben70_imp
