oil change
#51
(07-19-2013, 04:38 AM)The ferret_imp Wrote: Well furious has a point. The pants, be they jeans or riding pants have insulation qualities that protect you from the heat. Think this bike is hot? Try riding an ST1300 without proper riding pants in the summer.
Hi Ferret ,
Thanks , But the reason why brought this point was , I rode my bike with shorts-on several times before and I never felt this hot like yesterday .... May be I am hallucianting in broad daylight ....Thought of clarifying , cause this is the first time that i am doing something by my own like changing the oil and thought I messed up something ...
Also-- Thanks a lot for the comprehensive step by step instrction for the 600-Miles servicing ....
glad the instructions could help. This bike is so simple to change oil pn its really hard to mess it up so Im sure you did fine.
Hmmm, Is it any hotter out , where you are now, than when you rode it before? My sources say it came with 10w 40 in it, so if you put 10/40 back in it, there should be no difference in heat the engine emits.
I run GN4 10w40 in mine and it was stinking hot this week riding when we weren't in the mountains. 75 degrees in the mountains, 95 degrees when we came down in the valleys. Wouldn't have wanted to be wearing shorts when riding in the valleys, thats for sure.
Nanotech, it might be because you had your shorts on. Air cooled engines gets hot in second , try opening the throttle up while you are cruising for a quick acceleration and you can feel her roaring up and building up some good heat in a flash, she is a big air cooled 4 that's why. nothing to worry about.
(07-19-2013, 05:25 AM)The ferret_imp Wrote: glad the instructions could help. This bike is so simple to change oil pn its really hard to mess it up so Im sure you did fine.
Hi Ferret ....I am In Napervile IL and it's quite hot here and I use the exact oil (GN4 10w40 ) that you are referring . Any ways let's see . After all the advices from all of you I think it's nothing to worry abt...I will Plan for a trip tomorrow ... .....
(07-19-2013, 06:14 AM)wildezt_imp Wrote: Nanotech, it might be because you had your shorts on. Air cooled engines gets hot in second , try opening the throttle up while you are cruising for a quick acceleration and you can feel her roaring up and building up some good heat in a flash, she is a big air cooled 4 that's why. nothing to worry about.
Thanks Wildezt ......Very Nice piece of advice .....
I know people do but I'll never ride in shorts. Not condemning anyone. Their choice. Boots, gloves, long pants, glasses & lid @ a minimum for me. Even 1/2 mile trip to store.
NP at all Nano Tech!
(07-19-2013, 01:54 PM)FUZZY_imp Wrote: I know people do but I'll never ride in shorts. Not condemning anyone. Their choice. Boots, gloves, long pants, glasses & lid @ a minimum for me. Even 1/2 mile trip to store.
+100, you never know what comes around that corner, or what flies into your eyes.
Frankly speaking fuzzy/wildezt...I respect all of your advices and will try to stick to them....Just FYI I was wearing helmet...
Just got done with my first change of oil. Oil plug was so loose I felt no effort in starting it and it came all the way out by hand. Used an extension on my filter, it too was ridiculously easy to start, and I was able to get it off with no trouble.
Sadly, the stupid filter wrench decided to be difficult after putting on the new filter, and wouldn't come off without some percussive maintenance.
Took 4 quarts and so far, its right above the full line, but that was after a short ride. I'll wring it or tomorrow.
(07-20-2013, 01:18 PM)Obliviontoad_imp Wrote: Just got done with my first change of oil. Oil plug was so loose I felt no effort in starting it and it came all the way out by hand. Used an extension on my filter, it too was ridiculously easy to start, and I was able to get it off with no trouble.
Should only hand tighten new filter.
My filter wrench is the Imperial IF-6514 and it was so tight I could not get on off the old filter and had to remove the socket handle and thread the whole assembly (filter and wrench) out between the pipes. Then when I tried it on the new filter I had no confidence I could get the wrench off when I was done tightening it.
Now although Car Talk's Ray Magliozzi has no use for a Dremel Motor Tool, I can assure you I do. I got out the old Dremel with a grinding stone and took about .003" off the inside surfaces of filter wrench.
My filter is installed to spec. and the wrench came off with a little back pressure on the socket handle. Here is a photo of my wrench.
  tire change Tom_imp 7 740 05-31-2021, 11:37 PM
Last Post: Tom_imp
  First oil change for this heathen koehlerk_imp 67 4,852 02-20-2021, 02:42 PM
  Oil Change interest? Scotty_imp 10 929 09-15-2020, 09:40 PM
  Oil Change Time! Jambo_imp 57 4,143 09-06-2020, 08:40 AM
Last Post: Jambo_imp
  Oil change before/after winter? HikerToo_imp 11 835 02-09-2019, 05:08 AM
  Oil Filter Change: Every oil change or every other? dbarkdoll_imp 22 1,310 04-17-2018, 12:46 AM
Last Post: Knave_imp
  Oil change questions... ride4now_imp 16 1,065 04-12-2018, 02:12 PM
  fork oil change Houtman_imp 4 427 03-12-2018, 08:46 PM
Last Post: Wisedrum
  First oil change SportsterDoc 30 2,355 11-28-2017, 09:24 AM
Last Post: SportsterDoc
  Completed second oil change (DIY) venturer434_imp 5 488 05-11-2017, 07:47 PM
Last Post: Rocky_imp
