Honda CB1100 Rough Idle Solution
#51
my software cant reflash a say "a23" to the "a24" with out corrupting it im pretty sure they have different firmware inside im sure honda has some cool programs to flash them though
(08-31-2023, 09:13 PM)The ferret_imp Wrote: If im not mistaken*, in Europe, there was an official reflash of the ECU available to cure the problem. It was never offered or made available here in the states, so our only resort was to buy and replace the ECU with an ECU with an updated part number.
You're right, ferret. My idle problem was cured by a new injection software programm by Honda. I had to 'step on their feet' to get it but it worked and I got it without paying money for it. But it took a while.
I tried real hard to get Honda USA to upgrade my ECU, but they refused. They told me it was illegal for them to modify anything related to the emissions system.
I had the rough idle and a surging idle about 2yrs ago. Found a couple of the rubber intake runners were leaking (vacuum leak). Snugged up the clamps, and all was good.
Arrows show the four clamps. Good luck.
This is what I like, DIAGNOSES, not blind parts replacement!!
Good job Thumbs Up
(09-04-2023, 08:17 PM)Razor_imp Wrote: I had the rough idle and a surging idle about 2yrs ago. Found a couple of the rubber intake runners were leaking (vacuum leak). Snugged up the clamps, and all was good.
Razor, thank you so much for your timely post. All of my clamps were very loose and made the bike run lean when hot, which made it surge at small throttle openings and drive me crazy. Also sometimes the idle would drop to 800 rpm when hot. After tightening the clamps and taking it for a 90 mile test drive, it is running like new.
Good deal Rick!
  CB1100 Idle speed instability problem ericlo69_imp 1,434 117,326 07-26-2026, 01:51 AM
  idle problem update 1973cb750 37 2,075 05-12-2026, 08:38 PM
Last Post: rdprdp01
  Idle a little rough and miss fire when revved johnnyH_imp 3 412 09-15-2024, 12:16 AM
  another idle thread Tom_imp 11 972 11-20-2023, 01:30 PM
  TPS Sourcing because of High Idle Obi-wan Kenobi_imp 38 2,555 09-14-2023, 10:08 PM
  High idle mattmcuomo@yahoo.com 7 682 10-29-2022, 11:09 AM
  Fast Idle Problem Solved Nachodaddy 17 1,456 10-08-2022, 09:18 AM
   Dutch's High idle thread DutchRutter 17 1,519 09-27-2022, 01:55 AM
Last Post: DutchRutter
  Another High Idle Problem emptysea 60 3,991 07-05-2022, 11:41 AM
  Really high idle Gordo_imp 124 10,026 11-16-2021, 02:37 PM
