Larger rear sprocket
#51
I’m not sure if the 2003 uses the same part. The 900RR generation that would fit is the one from the early 90s 9394 etc..
someone find me a 37 tooth for less than $60. the JT is aluminum. I'm not paying $60 for an aluminum sprocket. if it was steel I would pay it because it would last.
(04-03-2018, 03:16 AM)PowerDubs_imp Wrote: I’m not sure if the 2003 uses the same part. The 900RR generation that would fit is the one from the early 90s 9394 etc..
OK, there are two offerings for the 1994 CBR900RRR:
[ul] [li]"Sprocket Comp., Final Driven (42T) P/N 41200-MW0-000"[/li] [li]"Sprocket Final Driven (43T) P/N 41201-MAL-600"
[/li][/ul] Again, check the parts fiche [url=http://www.peterhillhonda.com.au/honda-parts-epc]here. Peter Hill seems to have a good historic parts list. For what it's worth, the 43T sprocket part number matches with that on PartsFish, although there is no 42T sprocket there. Makes me think the P/N is probably right. Mr T could get it, maybe, if you can't source it locally.
Thanks. Appears to be discontinued. I guess I'll just order the JT sprocket one above.
Have you tried Mr T?
No, but if Honda is listing it as discontinued that is different than him just tracking down a foreign part #.
Also- it appears that even when available, the cost was 5 times the cost of a comparable aftermarket part which is insane. A little more cost for a little more piece of mind- ok. But not that much.
Smile
If the early 900RR sprocket is compatible with the CB, are there any quality 42 tooth aftermarket options for it? Maybe cross-referencing to a different model will yield better results than the CB. I’ve seen that before with a few other parts.
(04-04-2018, 09:46 AM)Flytech99_imp Wrote: If the early 900RR sprocket is compatible with the CB, are there any quality 42 tooth aftermarket options for it? Maybe cross-referencing to a different model will yield better results than the CB. I’ve seen that before with a few other parts.
That's exactly what we did with JT Sprocket. This is the result. Same part number for CB1100 and 900RR.[Image: ab2eba83fd3c2b6046b287c793db9774.jpg]
That's exactly what we did with JT Sprocket. This is the result. Same part number for CB1100 and 900RR.[Image: 9b2f763d7a455f8371ae24024d9df1b0.jpg]
Gotcha! I looked at that page wrong the first time. I see now the part number is the “same” although the number of teeth vary based on application.
Smile
Yup
  Advice on sprocket replacement? Inhouse Bob 5 557 06-24-2025, 12:57 PM
  Going up 1 on the front sprocket DBM_imp 17 1,309 08-21-2018, 08:36 AM
Last Post: riggies_imp
  Chain and sprocket replacement cost ecka00_imp 2 278 03-16-2016, 07:22 AM
Last Post: Motogeezer1949_imp
  larger tanks on the '14s. Olyrider 1 219 05-12-2015, 05:52 AM
