What did you do on or to your CB 1100 today Part 2
#51
I did the first replacement, 2 sprockets, chain and rubber dampers/pads, at about 36,000 miles, but the chain was not lubricated very often... After replacing it with original parts, I did another 50,000 miles, lubricating the chain very often and not needing replacement, and then I sold my white  CB standard.
Frequent lube is the key issue!!
           "Drop a gear and disappear"®
'24 Kawi Z650RS - Hooligan®
            *Grand Chancellor*
Got the CB1100 on the road after a couple of months away. Felt good, although, for the first time since I've had it, it took a while to start.
(05-07-2025, 03:15 PM)Cormanus Wrote: Got the CB1100 on the road after a couple of months away. Felt good, although, for the first time since I've had it, it took a while to start.
Fresh gas and maybe a good hot battery would help
2014 Cb1100 STANDARD #2061  ECU flashing.    Biker        https://www.facebook.com/cj.h.pfeiffer
Thanks 1973cb750. Battery was good — had been on a tender — so, yes, petrol the likely problem. I forgot to put stabil in when I parked it.
  The Birthday Thread Part 2 the Ferret 241 18,276 Today, 07:55 AM
  What did you do on or to your CB 1100 today rdprdp01 481 49,112 08-12-2026, 06:26 PM
Last Post: Lunchbag
  Correct Part No sprint 6 643 02-16-2025, 06:17 AM
  Part that holds speedometer (HP-0856-001) jaceobrien_imp 4 634 09-12-2022, 05:12 AM
Last Post: jaceobrien_imp
  HONDA Part numbering system logic. 17-CB-002 5 757 04-06-2022, 10:47 AM
  Polish Engine side cover part number Streetbiker_imp 18 1,786 08-22-2020, 05:22 PM
Last Post: FLYTYM_imp
  Honest opinions please,part II FLYTYM_imp 16 1,236 08-25-2019, 07:18 AM
  Please help id part MikeD_imp 11 912 05-01-2017, 03:16 AM
Last Post: MikeD_imp
  Why would anyone part out a perfectly good CB1100? ecka00_imp 13 962 02-26-2017, 05:46 AM
Last Post: GaryMNM_imp
  2014 Blue gas tank part number? Kawiboy_imp 3 375 11-18-2015, 05:59 PM
Last Post: Randy B
