2018 CB1100RS
#51
I’m just curious: why would spinning the wheel backwards make a difference?
(02-20-2019, 10:59 AM)Cormanus_imp Wrote: I’m just curious: why would spinning the wheel backwards make a difference?
It draws the lube into the links
Does it not do that while spinning forwards?
Thinking about it, I always used to do that, back in the '60s - spun the wheel backwards, lube the bottom run. I suppose my thinking then was the sharper bend on the engine sprocket permitted more extreme movement of the links to draw in the lube better? But this is all a bit "anal", isn't it? I was very anal then about all aspects of motorcycling. As I'm older, I'm less so now! Smile
(02-20-2019, 04:14 PM)Cormanus_imp Wrote: Does it not do that while spinning forwards?
I think, there is some relation to where you're living, northern or southern hemisphere. It has something to do with the Coriolis force. Cool
Django... Big Grin
Django could well be right. It's very comforting. I'll keep oiking the bike onto the centre stand, starting it up, putting it in gear and squirting oil all over the place. And because of Coriolis, the wheel will be turning the right way! Tongue
If you run the bike in top gear at 8000 rpm with the garage door open you will lubricate the whole neighborhood.
(02-20-2019, 10:48 PM)Houtman_imp Wrote: If you run the bike in top gear at 8000 rpm with the garage door open you will lubricate the whole neighborhood.
ROFL & +1^
Come to think of it, I used to pull the rear wheel backwards and spray at the rear sprocket equator. In general, I don't care because I am not too passionate about chains. Dodgy
  2022 Honda CB1100RS Final Edition photos jerrycon_imp 23 1,682 12-08-2022, 12:12 PM
  Looking for CB1100RS darmahman_imp 31 1,958 05-17-2022, 07:06 AM
   New friend for my cb1100rs Mixagon_imp 6 581 05-06-2022, 06:30 AM
Last Post: treedoc_imp
  importing a CB1100RS into the US jdiv_imp 35 2,678 01-25-2022, 03:39 AM
  Exceptionally good review of the CB1100RS Ulvetanna_imp 24 2,129 08-24-2021, 03:03 PM
Last Post: michael1954
  How to make the CB1100rs perform better Saltani_imp 26 2,090 12-15-2019, 04:07 AM
  2018 Bike Thefts Numbers clearviewx 8 787 09-21-2019, 02:46 AM
Last Post: fritzwilliger_imp
  '17 CB1100RS tank range? hh007_imp 3 384 06-25-2018, 05:33 PM
Last Post: hh007_imp
  2018 cb1100rs first impressions... Jfro5687_imp 22 1,581 06-22-2018, 08:42 AM
Last Post: LongRanger_imp
  2018 EX blue pdedse 19 1,210 04-15-2018, 09:21 AM
Last Post: Perry_imp
